After a few trials and errors, I successfully included both the zone controller and the local load relay associated with a new Vizia RF+ VRCZ4-MR. See details for those 2 devices at the end of this post.
My 2 problems are:
1. I see no way of "catching" the event raised by a button push. E.g., if I create a "Device State Changed" trigger on the controller device (node ID 56 below), nothing ever happens.
2. I thought I would create a workaround by associating an on-off virtual device to each of the 4 zones I want to control. Unfortunately, virtual devices don't show up in the of devices I can associate. Note that I can successfully associate physical devices, but I really want to create more complex scenarios, hence the need to either catch the z-wave event or associate it with a virtual device.
Thanks for advising!
Feb 23, 2015, 3:18:45 PM
Z-Wave Indigo Device "scn:LivingRm" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.301
Node ID: 56
Model: Portable Controller
Model ID: 12020243
Manufacturer: Leviton
Manufacturer ID: 001D
Protocol Version: 2.67
Application Version: 0.02
Model Definition Version: 0
Library Type: 7
Class Name: Portable Controller
Class Hierarchy: 02 : 01 : 00
Command Class Base: 00
Command Versions: 20v1 82v1 85v1 86v1 2Dv1 91v1 72v1 73v1 77v1 7Cv1
Features: - none -
Neighbors: 1, 2, 21, 23, 24, 25, 35, 36, 38, 43
Associations: 1:[1, 57] 2:[1] 3:[] 4:[]
Config Values: - none -
Feb 23, 2015, 3:19:12 PM
Z-Wave Indigo Device "lgt:LivingRmRecessedSittingArea" Z-Wave Properties:
Node ID: 57
Model: Relay Switch
Model ID: 12020243
Library Type: 7
Class Name: Relay Switch
Class Hierarchy: 03 : 10 : 00
Command Class Base: 25
Command Versions: 20v1 25v1 86v1 2Bv1 2Cv1 91v1 72v1 73v1 77v1 85v1
Features: - none -
Neighbors: 1, 2, 3, 21, 23, 24, 35, 43
Associations: 1:[1]
