There has been too much focus on other priorities than the backup software as of late.
It was projected that it will be available December 15th, but there are always delays and i believe it should be available in Janurary or Februrary.
http://forum.micasaverde.com/index.php?topic=9099.15
Quote from: strangely on January 16, 2012, 11:32:44 am
you can plug in your Aeon stick and change Vera to use the Aeon Stick instead! You do this by going to the Zwave settings and changeing the default port from /dev/ttyS0 to /dev/ttyUSB0 or /dev/ttyUSB1 (depends on which USB port its plugged into). After saving and rebooting, it should come up with your exisitng devices from the Aeon stick.
For reference: the Aeon Labs USB Z-Wave stick works fine in Vera Lite's USB slot, using /dev/ttyUSB0 (note capitalization). If you restore a backup made from a Vera2, it will use the value from the backup (/dev/tts/usb/0 or /dev/tts/usb/1) and will need to be manually changed.
Jann wrote:If I do in batches of 5 do I plug in the Gen5 after the first 5 to reassign IDs -- or will that screw up the rest of the "unassigned-to-Gen5" devices?
Users browsing this forum: No registered users and 18 guests
