https://byjasco.com/products/ge-z-wave- ... ion-switch
Excited about this switch. Love to see it supported soon!
Indigo Z-Wave Version: 2.0.111
Node ID: 41
Model: Relay Power Switch
Model ID: 494D3032
Manufacturer: General Electric
Manufacturer ID: 0063
Protocol Version: 4.54
Application Version: 5.38
Model Definition Version: 0
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 85v1 86v1 8Ev1 56v1 59v1 5Av1 5Ev1 60v4 25v1 27v1 2Bv1 2Cv1 70v1 71v1 72v1 73v1 7Av1
Multi-Endpoint Types: 1:(10 : 01), 2:(07 : 01)
Multi-Endpoint Classes: 1:[5E 59 25], 2:[5E 59 71]
Features: routing, beaming
Neighbors: 9, 10, 11, 12, 13, 14, 15, 20, 22, 23, 25, 26, 27, 28, 30, 31, 33, 34, 35, 36, 38, 39, 40
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Z-Wave Debug starting node healing thread
Z-Wave Debug starting node status polling thread
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 29 09 71 05 00 00 00 FF 07 08 00 50
Z-Wave Debug . . requestAlarmSensorStatus: node 041, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 8, classSubKeyExt 7100000708
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 29 03 25 03 FF 01
Z-Wave Debug . . requestRelayStatus: node 041, endpoint None, value 255
Z-Wave received "Ford Bathroom Light" status update is on
Aug 24, 2018 at 5:24:43 PM
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 29 09 71 05 00 00 00 FF 07 00 00 58
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 0, classSubKeyExt 7100000700
Aug 24, 2018 at 5:24:58 PM
Z-Wave Syncing - started for "047 - Mulitlevel Switch"
Z-Wave Syncing - retrieved module neighbors list: 3, 4, 5, 11, 15, 24, 28, 30, 43, 44, 46
Z-Wave Syncing - assigning return route to "047 - Mulitlevel Switch"
Z-Wave Syncing - retrieved manufacture and model names: General Electric - 0063, Dimmable Power Switch - 494D3034
Z-Wave Syncing - retrieved protocol version 4.34, app version 5.32
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 26v2 86v1 27v1 2Bv1 2Cv1 8Ev1 70v1 71v1 72v1 73v1 56v1 59v1 5Av1 7Av1 5Ev1 85v1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved multi-endpoint types: 1:(11 : 01), 2:(07 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 59 26], 2:[5E 59 71]
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - complete
Z-Wave sent "047 - Mulitlevel Switch" status request
Z-Wave sent "047 - Notification Sensor" status request
Z-Wave Indigo Device "047 - Mulitlevel Switch" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.119
Node ID: 47
Model: Dimmable Power Switch
Model ID: 494D3034
Protocol Version: 4.34
Application Version: 5.32
Library Type: 3
Class Name: Dimmable Power Switch
Class Hierarchy: 04 : 11 : 01
Command Class Base: 26
Command Versions: 20v1 85v1 86v1 8Ev1 56v1 59v1 5Av1 5Ev1 60v4 26v2 27v1 2Bv1 2Cv1 70v1 71v1 72v1 73v1 7Av1
Multi-Endpoint Types: 1:(11 : 01), 2:(07 : 01)
Multi-Endpoint Classes: 1:[5E 59 26], 2:[5E 59 71]
Neighbors: 3, 4, 5, 11, 15, 24, 28, 30, 43, 44, 46
Oct 6, 2018 at 9:33:42 AM
Z-Wave received "047 - Mulitlevel Switch" status update brightness 100. <-- turned on at switch
Z-Wave received "047 - Mulitlevel Switch" status update brightness 48. <-- dimmed at switch
Z-Wave received "047 - Mulitlevel Switch" status update is off <-- turned off at switch
Z-Wave received "047 - Notification Sensor" status update is off. <-- automatic switch report
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 2F 09 71 05 00 00 00 FF 07 08 00 56
Z-Wave Debug . . requestAlarmSensorStatus: node 047, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug RCVD requestDimmerStatus: 01 09 00 04 00 2F 03 26 03 32 C9
Z-Wave Debug . . requestDimmerStatus: node 047, endpoint None, value 50
Z-Wave received "047 - Mulitlevel Switch" status update brightness 51
howartp wrote:Dave, can you add association for group 2 and 3 to Indigo (node 1)?
Multitool ========================= 048 - Mulitlevel Switch Dict =========================
Multitool
address : 48
batteryLevel : None
blueLevel : None
brightness : 0
buttonGroupCount : 0
configured : True
defaultBrightness : 100
description :
deviceTypeId : zwDimmerType
displayStateValRaw : 0
displayStateValUi : 0
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 1262568842
com.perceptiveautomation.indigoplugin.zwave : (dict)
address : 48 (integer)
indigoObjVersion : 8 (integer)
userPollAfterActivity : true (bool)
userPollInterval : 0 (integer)
userPollingEnabled : true (bool)
userWakeInterval : 60 (integer)
version : 5.32 (string)
zwAppVersMajor : 5 (integer)
zwAppVersMinor : 32 (integer)
zwAssociationsMap : (dict)
g1 : (list)
Item : 1 (integer)
g2 : (list)
Item : 1 (integer)
g3 : (list)
Item : 1 (integer)
zwAssociationsMapStr : 1:[1] 2:[1] 3:[1] (string)
zwClassCmdBase : 38 (integer)
zwClassCmdMap : (dict)
c112 : 1 (integer)
c113 : 1 (integer)
c114 : 1 (integer)
c115 : 1 (integer)
c122 : 1 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c142 : 1 (integer)
c32 : 1 (integer)
c38 : 2 (integer)
c39 : 1 (integer)
c43 : 1 (integer)
c44 : 1 (integer)
c86 : 1 (integer)
c89 : 1 (integer)
c90 : 1 (integer)
c94 : 1 (integer)
c96 : 4 (integer)
zwClassCmdMapStr : 20v1 85v1 86v1 8Ev1 56v1 59v1 5Av1 5Ev1 60v4 26v2 27v1 2Bv1 2Cv1 70v1 71v1 72v1 73v1 7Av1 (string)
zwClassIds : (list)
Item : 4 (integer)
Item : 17 (integer)
Item : 1 (integer)
zwClassInstanceCountMap : (dict)
zwClassInstanceCountMapStr : - none - (string)
zwClassName : Dimmable Power Switch (string)
zwConfigVals : (dict)
zwConfigValsStr : - none - (string)
zwDevSubIndex : 0 (integer)
zwEncryptClassCmdMap : (dict)
zwEncryptClassCmdMapStr : - none - (string)
zwEncryptionStatusStr : Not Supported (string)
zwEndpointClassMap : (dict)
e1 : (list)
Item : 94 (integer)
Item : 89 (integer)
Item : 38 (integer)
e2 : (list)
Item : 94 (integer)
Item : 89 (integer)
Item : 113 (integer)
zwEndpointClassMapStr : 1:[5E 59 26], 2:[5E 59 71] (string)
zwEndpointDevTypeMap : (dict)
e1 : (list)
Item : 17 (integer)
Item : 1 (integer)
e2 : (list)
Item : 7 (integer)
Item : 1 (integer)
zwEndpointDevTypeMapStr : 1:(11 : 01), 2:(07 : 01) (string)
zwFeatureListStr : routing, beaming (string)
zwLibType : 3 (integer)
zwManufactureId : 99 (integer)
zwManufactureName : General Electric (string)
zwModelDefnVers : 0 (integer)
zwModelId : 1229795380 (integer)
zwModelName : Dimmable Power Switch (string)
zwNodeNeighbors : (list)
Item : 3 (integer)
Item : 4 (integer)
Item : 5 (integer)
Item : 8 (integer)
Item : 10 (integer)
Item : 11 (integer)
Item : 12 (integer)
Item : 15 (integer)
Item : 16 (integer)
Item : 21 (integer)
Item : 24 (integer)
Item : 27 (integer)
Item : 28 (integer)
Item : 30 (integer)
Item : 43 (integer)
Item : 46 (integer)
zwNodeNeighborsStr : 3, 4, 5, 8, 10, 11, 12, 15, 16, 21, 24, 27, 28, 30, 43, 46 (string)
zwProtoVersMajor : 4 (integer)
zwProtoVersMinor : 34 (integer)
zwShowDumpDevToLog : false (bool)
zwShowMainUI : true (bool)
zwShowManualModifyConfigParmUI : true (bool)
zwShowPollingUI : true (bool)
zwShowSubmitModelInfoUI : true (bool)
zwShowWakeIntervalUI : false (bool)
zwWakeInterval : 0 (integer)
greenLevel : None
lastChanged : 2018-10-08 08:00:44
lastSuccessfulComm : 2018-10-08 08:00:44
ledStates : []
model : Dimmable Power Switch
name : 048 - Mulitlevel Switch
onBrightensToDefaultToggle : False
onBrightensToLast : True
onState : False
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
g1 : (list)
Item : 1 (integer)
g2 : (list)
Item : 1 (integer)
g3 : (list)
Item : 1 (integer)
c112 : 1 (integer)
c113 : 1 (integer)
c114 : 1 (integer)
c115 : 1 (integer)
c122 : 1 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c142 : 1 (integer)
c32 : 1 (integer)
c38 : 2 (integer)
c39 : 1 (integer)
c43 : 1 (integer)
c44 : 1 (integer)
c86 : 1 (integer)
c89 : 1 (integer)
c90 : 1 (integer)
c94 : 1 (integer)
c96 : 4 (integer)
zwClassIds : (list)
Item : 4 (integer)
Item : 17 (integer)
Item : 1 (integer)
e1 : (list)
Item : 94 (integer)
Item : 89 (integer)
Item : 38 (integer)
e2 : (list)
Item : 94 (integer)
Item : 89 (integer)
e1 : (list)
Item : 17 (integer)
Item : 1 (integer)
e2 : (list)
Item : 7 (integer)
Item : 1 (integer)
Item : 3 (integer)
Item : 4 (integer)
Item : 5 (integer)
Item : 8 (integer)
Item : 10 (integer)
Item : 11 (integer)
Item : 12 (integer)
Item : 15 (integer)
Item : 16 (integer)
Item : 21 (integer)
Item : 24 (integer)
Item : 27 (integer)
Item : 28 (integer)
Item : 30 (integer)
Item : 43 (integer)
Item : 46 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
pluginProps : com.fogbert.indigoplugin.multitool : (dict)
protocol : ZWave
redLevel : None
remoteDisplay : True
states : States : (dict)
brightnessLevel : 0 (integer)
subModel : Mulitlevel Switch
supportsAllOff : False
supportsColor : False
supportsRGB : False
supportsStatusRequest : True
supportsWhite : False
version : 5.32
whiteLevel : None
whiteLevel2 : None
whiteTemperature : None
Multitool ================================================================================
