It suggests there is parameter that defaults to 0, that can be used to set a detection delay, to avoid continuous notifications when the light sensor is detecting a flashing LED
According to the documentation, the parameter is 5 and is 1 Byte
The delay can be between 0-20 seconds, with 0 being the default and is also 1 Byte.
What would I send to change it to 20 second, then what I would I send to change it back to 0, if it doesn't work?
FYI: The light sensor connected to my Samsung Washer (which does not blink) has been rock solid for the past seven (7) months. I have a trigger configured to detect when the status light becomes Off, which then makes an announcement on Echo's in specific rooms.
In an attempt to use a second sensor on a brand new Electrolux dryer which is super quiet (in comparison to the 11 year old dryer it replaced), the Start/Stop indicator blinks, so I'm curious if this hardware delay will help simplify detecting when the LED turns "Off".
- Code: Select all
Nov 29, 2022 at 1:37:22 PM
Z-Wave received "052 - Light Sensor - Dryer" status update is off
Trigger Electrolux Dryer Light Sensor becomes Off
Z-Wave received "052 - Light Sensor - Dryer" status update is on
Z-Wave received "052 - Temperature - Dryer" sensor update to 25.6 °C
If this isn't an option, I am trialing the use of two (2) triggers. An "On" trigger to store the date/time in a variable. Then an "Off" trigger which uses as a condition, if the value stored in the "On" date/time variable is greater than 20 seconds.
