ZW4006 Smart Motion Switch 26931 won't sync under 2021.2
Sun Jan 23, 2022 6:53 pm
Butch2427 offline
Back in November (under indigo 2021.1) I installed a GE zwave smart motion switch (26931). It included and synced just fine and works great. I've since upgraded to Indigo 2021.2 and today tried to install another ZW4006. It included smoothly but won't sync:
Jan 23, 2022 at 4:36:11 PM
Z-Wave Syncing - started for "098 - Relay Power Switch"
Z-Wave Syncing - retrieved module neighbors list: 7, 9, 10, 11, 13, 14, 15, 16, 17, 20, 22, 23, 24, 25, 36, 42, 45, 46, 47, 48, 51, 54, 58, 59, 60, 61, 62, 63, 64, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 77, 78
Z-Wave Syncing - assigning return route to "098 - Relay Power Switch"
Z-Wave Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/IndigoPluginHost.app/Contents/Resources/PlugIns/serialinterface.py", line 517, in startCommThread
self.processCommThread()
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/IndigoPluginHost.app/Contents/Resources/PlugIns/serialinterface.py", line 691, in processCommThread
self.processQueueInPacket(packet) # Subclass is required to define.
File "zwaveinterface.py", line 2883, in processQueueInPacket
File "zwaveinterface.py", line 2855, in _processFuncCall
File "zwaveinterface.py", line 2921, in _processCommandReply
File "zwaveinterface.py", line 2904, in _processFuncTriggersAndBroadcast
File "zwaveinterface.py", line 2853, in _processFuncCall
File "zwavecmd_manufactureinfo.py", line 79, in _processManufactureInfo
File "zwavenode.py", line 607, in _updateModelInfoFromIDs
AttributeError: 'module' object has no attribute 'kModelDefinition'
Z-Wave Error exc type is <type 'exceptions.AttributeError'>
Z-Wave Error restarting serial connection in 5.0 seconds
Interface Failure lost connection with interface
Z-Wave connected to Z-Stick Gen5 (ZW090) interface on /dev/cu.usbmodem14401 (firmware 1.00, SDK unknown)
Z-Wave Error Error trying to communicate with "098 - Relay Power Switch".
Z-Wave Error failed to get module 058 info from controller ('module' object has no attribute 'kModelDefinition')
Z-Wave found module included in controller with no matching device (missing or disabled): 098 - Relay Power Switch
I closed my server, and rebooted under 2021.1 and it sync's just fine. I also tried to re-upgrade to 2021.2 after the sync but to no avail.
Any ideas?
Mon Jan 24, 2022 4:28 pm
Re: ZW4006 Smart Motion Switch 26931 won't sync under 2021.2
I'm going to email you offline with a solution.
Also I'm going to lock this thread since it is the same problem mentioned here, so if you need to reply just do so on that thread.
Users browsing this forum: No registered users and 31 guests
