Z-Wave Error with GE enbrighten Smart Motion Switch (26931)
Wed Jan 19, 2022 12:59 am
GRWilde offline
I have begun switching over from my many Insteon devices (several of which are failing) to Z-Wave devices. I have a Z-Stick Gen5+ and am using Indigo 2021.2. I have successfully added several Z-Wave devices but have encountered Indigo errors when trying to add a Z-Wave GE Enbrighten Smart Motion Switch (26931). I had no problem adding a dimmer version of this switch (26933). Both are listed as supported Indigo Z-Wave devices. The error message follows:
Z-Wave Syncing - started for "002 - Relay Power Switch"
Z-Wave Syncing - retrieved module neighbors list: 1, 3, 4
Z-Wave Syncing - assigning return route to "002 - Relay Power Switch"
Z-Wave Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/IndigoPluginHost.app/Contents/Resources/PlugIns/serialinterface.py", line 517, in startCommThread
self.processCommThread()
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/IndigoPluginHost.app/Contents/Resources/PlugIns/serialinterface.py", line 691, in processCommThread
self.processQueueInPacket(packet) # Subclass is required to define.
File "zwaveinterface.py", line 2883, in processQueueInPacket
File "zwaveinterface.py", line 2855, in _processFuncCall
File "zwaveinterface.py", line 2921, in _processCommandReply
File "zwaveinterface.py", line 2904, in _processFuncTriggersAndBroadcast
File "zwaveinterface.py", line 2853, in _processFuncCall
File "zwavecmd_manufactureinfo.py", line 79, in _processManufactureInfo
File "zwavenode.py", line 605, in _updateModelInfoFromIDs
File "zwavedev_ge_smartmotionswitch.py", line 3, in init zwavedev_ge_smartmotionswitch (/Library/Application Support/Perceptive Automation/Indigo 2021.2/Plugins/Z-Wave.indigoPlugin/Contents/Server Plugin-build/zwavedev_ge_smartmotionswitch.c:641)
File "zwavedev_ge_smartmotionswitch.py", line 18, in <module>
AttributeError: 'RelayDeviceSubTypes' object has no attribute 'Relay'
Z-Wave Error exc type is <type 'exceptions.AttributeError'>
Z-Wave Error restarting serial connection in 5.0 seconds
George Wilde
Thu Jan 20, 2022 5:12 pm
Re: Z-Wave Error with GE enbrighten Smart Motion Switch (269
Hi George,
We replied to your email with a solution.
For others: This will be fixed in the next Indigo release. If you need the fix sooner then contact us.
Tue May 10, 2022 3:24 pm
Indigo 2022.1.0 is now available and fixes this problem..
