Z-Wave Dimmers Activating Without Reason
Fri Oct 15, 2021 3:53 pm
dgwharrison offline
Hi, I have a house full of z-wave switches and dimmers which are all working very well with Indigo and Homekit; except for two dimmers in particular which are very problematic. The problem is they randomly turn on quite frequently, sometimes off as well but generally on. This is particularly a problem in the master bedroom. I've enabled the debug logs and i can see that the devices seem to think they're being activated, though they aren't. Strangely i find if i reboot the mac mini that hosts indigo the problems go away for a day or so. Log sample below:
16 Oct 2021 at 8:36:08 am
   Z-Wave Debug                    RCVD nodeInfoFrame: 01 14 00 49 84 04 0E 04 11 01 26 27 72 86 73 70 2B 2C 85 EF 20 83
   Z-Wave Debug                    queueing full request of "004 - Master Bedroom Main Light" (activity detected)
   Z-Wave Debug                    RCVD dimmerSetLevel: 01 09 00 04 08 04 03 20 01 FF 23
   Z-Wave Debug                    . .  dimmerSetLevel: node 004, endpoint None, value 255
   Z-Wave                          received "Master Bedroom Main Light" status update is on
   Z-Wave Debug                    RCVD dimmerSetLevel: 01 09 00 04 00 04 03 20 01 FF 2B
   Z-Wave Debug                    polling status of node "004 - Master Bedroom Main Light" (post-activity full request)
   Z-Wave Debug                    SENT requestDimmerStatus: 01 09 00 13 04 02 26 02 25 40 A2
   Z-Wave Debug                    RCVD requestDimmerStatus: 01 07 00 13 40 00 00 05 AE (node ACK)
   Z-Wave Debug                    waiting up to 3.0 seconds for module reply after sending request
   Z-Wave Debug                    RCVD requestDimmerStatus: 01 09 00 04 00 04 03 26 03 27 F7
   Z-Wave Debug                    . .  requestDimmerStatus: node 004, endpoint None, value 39
16 Oct 2021 at 8:38:10 am
   Z-Wave Debug                    RCVD nodeInfoFrame: 01 14 00 49 84 0A 0E 04 11 01 26 27 72 86 73 70 2B 2C 85 EF 20 8D
   Z-Wave Debug                    queueing full request of "010 - Dining Lounge" (activity detected)
   Z-Wave Debug                    RCVD dimmerSetLevel: 01 09 00 04 08 0A 03 20 01 FF 2D
   Z-Wave Debug                    . .  dimmerSetLevel: node 010, endpoint None, value 255
   Z-Wave                          received "Dining Lounge" status update is on
   Z-Wave Debug                    RCVD dimmerSetLevel: 01 09 00 04 00 0A 03 20 01 FF 25
   Z-Wave Debug                    polling status of node "010 - Dining Lounge" (post-activity full request)
   Z-Wave Debug                    SENT requestDimmerStatus: 01 09 00 13 0A 02 26 02 25 41 AD
   Z-Wave Debug                    RCVD requestDimmerStatus: 01 07 00 13 41 00 00 02 A8 (node ACK)
   Z-Wave Debug                    RCVD requestDimmerStatus: 01 09 00 04 00 0A 03 26 03 28 F6
   Z-Wave Debug                    . .  requestDimmerStatus: node 010, endpoint None, value 40
   Z-Wave Debug                    RCVD dimmerSetLevel: 01 09 00 04 08 04 03 20 01 00 DC
   Z-Wave Debug                    . .  dimmerSetLevel: node 004, endpoint None, value 0
   Z-Wave                          received "Master Bedroom Main Light" status update is off
   Z-Wave Debug                    RCVD dimmerSetLevel: 01 09 00 04 00 04 03 20 01 00 D4
   Z-Wave Debug                    SENT requestDimmerStatus: 01 09 00 13 04 02 26 02 25 42 A0
   Z-Wave Debug                    RCVD requestDimmerStatus: 01 07 00 13 42 00 00 04 AD (node ACK)
   Z-Wave Debug                    RCVD requestDimmerStatus: 01 09 00 04 00 04 03 26 03 00 D0
   Z-Wave Debug                    . .  requestDimmerStatus: node 004, endpoint None, value 0
Sun Oct 17, 2021 3:44 pm
Re: Z-Wave Dimmers Activating Without Reason
Unfortunately, I don't have much to suggest on this one. Definitely looks like the module is self-activating since there are no outbound Z-Wave commands from Indigo before it occurs. Try excluding and re-including them (then re-syncing them in Indigo). That normally acts as a factory reset for the module which might help.
Which brand/model dimmer is this?
Users browsing this forum: No registered users and 17 guests
