- Posted on
Sun Feb 21, 2021 3:31 am
rijdat
offline
Thanks for your very swift response Matt.
I have set up the trigger as you suggest but it is never triggered. I know the detector is working at least in test mode - with the back off and the tamper switch off - because it lights an LED when it detects movement, but nothing appears in the Event Log and the trigger I set up doesn't come into action.
Here is the info the device sent Indigo on Sync:
Syncing - started for "Kitchen motion sensor"
Z-Wave Syncing - retrieved module neighbors list: 1, 2, 3, 5, 7, 8, 13, 14, 15, 16, 19, 20
Z-Wave Syncing - assigning return route to "021 - Kitchen motion sensor"
Z-Wave Syncing - retrieved manufacture and model names: Everspring - 0060, Notification Sensor - 00010004
Z-Wave Syncing - retrieved protocol version 5.03, app version 1.01
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 55v1 98v1 59v1 5Av1 5Ev1 9Fv1 20v1 71v1 6Cv1 70v1 31v5 72v1 73v1 7Av1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, waking
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "021 - Kitchen motion sensor" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 1 associations: [1]
Z-Wave Syncing - retrieved group 2 associations: []
Z-Wave Syncing - group 1 association to interface already exists (skipping)
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - complete
Cheers, Richard
