Attempting to set LED on/off parameter for a GE Z-wave Fan Control. The Parameter in question is 3 and I want to set it to either 0 (on) or 255 (off). I can read the parameter properly, but setting a new value doesn't seem to work. I am using the Modify Configuration Parameter option from the Z-wave menu. Changing the setting manually at the switch (tap up quickly three times, followed by tapping down) does result in a new value being set. Here is the debug logging from the log:
SENT readConfigValue: 01 0A 00 13 11 03 70 05 03 25 3E 99
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 11 05 70 06 03 01 FF 6F
Z-Wave Debug . . requestConfigVal: node 017, parm index 3, value 255 (size 1)
Z-Wave retrieved parameter 3 value: 255 (size 1)
Z-Wave Debug SENT setConfigVal: 01 0C 00 13 11 05 70 04 03 01 00 25 3F 98
Z-Wave device "Office Room Fan" parameter 3 changed to 0
Z-Wave Debug SENT readConfigValue: 01 0A 00 13 11 03 70 05 03 25 40 E7
Any guidance on how to make this work properly? As the blue LED is really bright, I'd like to automatically turn it off at night and then back on during daylight. Thanks!
