Remotec ZRC-90 - syncs, no buttons detected
Thu Jun 21, 2018 10:04 am
autolog offline
Re: Remotec ZRC-90 - syncs, no buttons detected
I started on Option B (including/excluding until it loops around) - I have decided this is a non-runner as I have about 90 cycles to do and they are taking an age.
I think it will have to be Option A (full reset).
I will update this thread with the result when I can schedule some time to do this. :)
Sat Jun 23, 2018 6:20 am
autolog offline
ALL ZRC-90s NOW WORKING! :D
Factory reset my new Gen 5 Z-Stick and added in a number of strategically placed Gen 5 Aeotec and Fibaro UK sockets.
I then included my five ZRC-90 Scene Controllers at addresses 10 - 14 and they all work. All button presses recognised. :)
So, in conclusion, I think the problem was to do with the failing ZRC-90s addresses being 128 (probably?) and above and I suspect this is a bug in the ZRC-90 firmware.
I have now got to complete the task of re-including the remainder of my Z-Wave devices. Some will be easier to do than others. :wink:
Sat Jun 23, 2018 2:09 pm
Awesome troubleshooting on this one, and I'm glad you finally have them all working! My guess would be around 128 is the cut-off as well.
Mon Jul 02, 2018 1:11 pm
shapa offline
The problem is somewhere else.
"cycled" the device inclusion / exclusion until <128 (17 to be presize) - still the same issue.
Yes, in case of full UZB1 "erase" and inclusion - it works, so definitely the issue is in the firmware.
Mon Jul 02, 2018 1:40 pm
shapa offline
OK, it seems (googling) I found a reasonable explanation.
Memory/firmware issue, in case of a network bigger than ±90 devices, people are seeing the same issues (with different controllers).
Mon Jul 02, 2018 2:02 pm
autolog offline
Interesting info - I am glad I went for my option B and reset the Gen 5 Z-Stick. :)
I assume this issue is only when including / excluding?
I had a network with numbers up to ~170 (not all used) and the lower address numbered ZRC-90s worked OK but not the ones subsequently included at the higher addresses.
Tue Jul 03, 2018 2:49 am
shapa offline
It seems like it's not fully synchronizing or something like that.
I've got more than 90 real devices...
Tried to contact / open a case with Remotek.
Wed Jul 04, 2018 3:42 am
shapa offline
Initial feedback - 1.05 firmware is available...
Now I'm trying to understand the upgrade procedure.
Sat Oct 13, 2018 4:41 am
shapa offline
So, received the replacement.
Now the firmware version is 2.01, works fine with Indigo - all buttons detected.
So it's a 100% firmware issue, caused by "too many devices in the network).
Unfortunately, the only way to upgrade FW - to send it back to Remotec (via a reseller).
Z-Wave Syncing - started for "043 - Remote Control Simple"
Z-Wave Syncing - retrieved module neighbors list: - none -
Z-Wave Syncing - retrieved manufacture and model names: Remotec - 5254, Scene Master (ZRC-90) - 00018510
Z-Wave Syncing - retrieved protocol version 4.54, app version 2.01
Z-Wave Syncing - retrieved class hierarchy: Controller : Portable Controller : Remote Control Simple (01 : 01 : 06, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 21v1 72v1 73v1 59v1 5Av1 5Bv1 5Ev1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: battery, beaming, waking
Z-Wave Syncing - retrieved wake interval of 0 minutes
Z-Wave Syncing - device "043 - Remote Control Simple" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - created device "043 - Scene Master (ZRC-90)"
Z-Wave Syncing - complete
Sat Dec 01, 2018 5:49 pm
shapa offline
Update.
7+ devices with the latest FW - 100% reliable.
So the issue is "fixed".
Sun Dec 02, 2018 6:00 am
autolog offline
Hi @shapa,
Very useful info - thanks. :)
What process did you follow to get the firmware upgraded?
Wed Oct 09, 2019 12:56 pm
Dual offline
I just purchased and installed the ZRC-90. It sync'd fine and is firmware 2.01.
Is there a way to control it directly through Indigo or do I need the Scene Controller plugin? Only 1 device was created. In this thread @shapa mentions 7+ devices.
Indigo does receive the button presses according to the log. However I don't see how to create a trigger from the button press.
Button press:
   Z-Wave                          received "098 - Scene Master (ZRC-90)" button 6 pressed
   Z-Wave                          received "098 - Scene Master (ZRC-90)" button 8 pressed
Sync:
   Z-Wave                          Syncing - started for "098 - Remote Control Simple"
   Z-Wave                          Syncing - retrieved manufacture and model names: Remotec - 5254, Scene Master (ZRC-90) - 00008510
   Z-Wave                          Syncing - device "098 - Remote Control Simple" wake interval changed to 60 minutes
   Z-Wave                          Syncing - created device "098 - Scene Master (ZRC-90)"
Wed Oct 09, 2019 1:23 pm
Shapa physically owns 7+ of these devices, it’s not Indigo showing 7+ devices per unit.
I don’t know if Indigo supports it out of the box so-to-speak but I would expect it does by now. Regardless, it definitely works with Scene Controller plugin.
Fri Oct 11, 2019 2:59 pm
You can create Triggers of type Z-Wave Command Received then select the device and you should see the scene command for the buttons.
