Page 2 of 2
Re: Yosemite issues
PostPosted: Wed Jan 04, 2017 9:15 pm
by travisc
Hmmm, it does appear the 1-wire hardware is working ok. I re-connected my 1-wire bus and tested with Indigo 7 and it appears to work ok. To be honest I'm not sure what's going on. It seems the digitemp binary which the plugin uses to query the 1-wire bus isn't working reliably on your new setup for some reason. I didn't write the digitemp binary, it's a utility the plugin uses to do the dirty work. You could try running digitemp directly to take Indigo and the plugin out of the loop for testing purposes.
1. Disable the plugin in Indigo.
2. Open a terminal
3. Change to the plugin's folder ...
cd "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins (Disabled)/DigiTemp.indigoPlugin/Contents/Server Plugin/"
4. Tell Digitemp to walk the 1-wire bus ....
./digitemp_i386 -s /dev/tty.usbserial-A501HY6D -w
You should see a list of all the sensors on the bus. Try it a bunch of times and see if the output is consistent.
Re: Yosemite issues
PostPosted: Wed Jan 04, 2017 9:53 pm
by travisc
I may have jumped the gun there. I added a few more sensors and noticed the same thing as you. Sometimes I'd read 8 sensors, sometimes 2. I downloaded the latest digitemp binary, compiled it, and added it into the plugin. It seems to be more reliable.
When you scan for sensors, make sure it's not in the middle of polling. You might have to set the poll interval up high at 15 minutes so it won't poll while you're scanning.
Try this one. Please let me know if it's any better.
https://www.dropbox.com/s/d2smh2q0jvp6t0u/DigiTemp.indigoPlugin.zip?dl=0
Re: Yosemite issues
PostPosted: Thu Jan 05, 2017 8:06 pm
by btassias
Hi
Well i installed the modified plugin which brought me up to v1.0.4 I think it got worse. Still is random of what i get when i scan for sensors, as you see in the errors. the first 10 lines was repeated 4 or 5 times over in the log. It seemed to have a hard time finding the adaptor. As before what ever sensor wasn't found wont show up on Indigo. But when i did get all 6 sensor in the scan in this case the upper garage temp didnt show up on Indigo even though it was found in the scan, after a few tries the config screen shot looked normal. What i will can try next is what your previous sugestion was and try running DigiTemp directly and by pass Indigo and the plugin and see what that turns out.
Bret
DigiTemp Error DigiTemp Error:
Error 5: DS2480B Adapter Not Detected
Error 10: Read COM Failed
DigiTemp Scan complete, found 0 sensors.
Interface Failure lost connection with interface
Connected to PowerLinc 2413U interface on port usbserial-A700ahWO
PowerLinc address 18.B7.20, firmware version 9.2
Jan 5, 2017, 8:07:26 PM
DigiTemp Starting scan for 1-wire sensors.
DigiTemp Found sensor ID: 28CC9ECC03000026
DigiTemp Found sensor ID: 28AAF4BD030000DC
DigiTemp Found sensor ID: 28F607CD030000CF
DigiTemp Scan complete, found 3 sensors.
Jan 5, 2017, 8:07:57 PM
DigiTemp Found sensor ID: 28DE3ECC03000020
DigiTemp Found sensor ID: 28B39B6B020000CC
DigiTemp Found sensor ID: 289BEFBD0300000A
DigiTemp Scan complete, found 6 sensors.
DigiTemp DigiTemp initialized to read 6 sensors every 15 minute(s).
Jan 5, 2017, 8:08:53 PM
DigiTemp Error DigiTemp process exceeded our time limit so it was killed.
Jan 5, 2017, 8:09:31 PM
Jan 5, 2017, 8:10:00 PM
Schedule Poll Twilio For Message
Jan 5, 2017, 8:10:24 PM
Jan 5, 2017, 8:11:00 PM
Jan 5, 2017, 8:20:00 PM
Jan 5, 2017, 8:25:21 PM
Received INSTEON "Hallway Motion" on
Jan 5, 2017, 8:25:52 PM
Received INSTEON "Hallway Motion" off
DigiTemp Error "Upper Garage" sensor was not updated at the poll interval.
Re: Yosemite issues
PostPosted: Thu Jan 05, 2017 8:14 pm
by travisc
Hmmm. That's too bad. Unfortunately there's nothing more I can do from the plugin side. The digitemp binary or USB serial adapter is not working reliably on that system for some reason. I just checked my logs and I haven't had one bad read over almost 24 hours with 1.0.4 reading 8 sensors.
It looks like you're using an FTDI adapter, same as me.
I'm out of ideas. Sorry.
Re: Yosemite issues
PostPosted: Wed Jan 11, 2017 6:41 pm
by btassias
Hi
Well i was playing around with DigiTemp and tried what you suggested by taking out the plugin & Indigo and read the bus
and the results were all over the place like 2,6,0,1,6,0,2 then tried plugging the adaptor in different USB ports. next ill try
the old mac to see how that looks. then maybe do a time capsule backup and upgrade to Sierra to see what that does.
I'd thought i would let you know what i found. I guess its safe to say that Indigo and the plugin is ok. I'll just plug away at it
and at some point ill get it to work or at least find out what caused the errors.
Thanks again for your help
Bret
Indigos-Mac-mini:Server Plugin indigo$ ./digitemp_i386 -s /dev/tty.usbserial-A501HY6D -w
DigiTemp v3.7.1 Copyright 1996-2016 by Brian C. Lane
GNU General Public License v2.0 - http://www.digitemp.com
Turning off all DS2409 Couplers
Devices on the Main LAN
28CC9ECC03000026 : DS18B20 Temperature Sensor
28AAF4BD030000DC : DS18B20 Temperature Sensor
28F607CD030000CF : DS18B20 Temperature Sensor
28DE3ECC03000020 : DS18B20 Temperature Sensor
28B39B6B020000CC : DS18B20 Temperature Sensor
289BEFBD0300000A : DS18B20 Temperature Sensor
Re: Yosemite issues
PostPosted: Thu Jan 12, 2017 8:13 am
by travisc
Ok, sounds good. Let me know if you make any breakthroughs.
Re: Yosemite issues
PostPosted: Thu Jan 12, 2017 7:59 pm
by Fishysan
Hi Travis, also updated to v7..
I'm having similar problems. I got a sensor to be recognized by unplugging it, but it quickly lost it.
Turned on debug. I got;
   Stopped plugin "DigiTemp 1.0.3"
   Starting plugin "DigiTemp 1.0.3" (pid 3693)
   Started plugin "DigiTemp 1.0.3"
   DigiTemp Debug                  Read Sensor List Start
   DigiTemp Debug                  Error reading digitemp.conf file.
   DigiTemp Debug                  STATE: Test
And then on a scan, also;
   DigiTemp Debug                  STATE: Process Poll
   DigiTemp Debug                  DigiTemp Output:
   DigiTemp Debug                  OUTPUT:
So, it can't read digitemp.conf.. hmm - I can't find such a beast either.
Re: Yosemite issues
PostPosted: Thu Jan 12, 2017 8:00 pm
by Fishysan
Forgot to mention I'm on El Capitan though.
Re: Yosemite issues
PostPosted: Fri Jan 13, 2017 9:23 am
by travisc
Try running 1.0.4 from the DropBox link above. If that doesn't sort it out you can try running digitemp manually. You might be in the same boat.
If it can't find any sensors during a scan there won't be any config find. You have to successfully scan your sensors in the config for that file to exist.
Re: Yosemite issues
PostPosted: Wed Jan 18, 2017 6:58 pm
by btassias
Hi Travis
Well i just did an upgrade to Sierra tonight to see if that would help, But I'm still having the same issues as before with Yosemite.
i also tried using a powered USB hub in case the built in USB ports were limiting the current to power all the sensors , So as of now it
only works for me with Lion on older mini mac and not with Yosemite & Sierra on newer mini mac. I did a time capsule backup of Yosemite
before the upgrade in case i had more issues which i didn't so ill leave it at Sierra. Its starting to look like I'm having a hardware issue in the
newer mini mac reliably with the 1-wire USB dongle? just guessing . well I'm still plugging away at it.
Bret
Re: Yosemite issues
PostPosted: Thu Jan 19, 2017 9:20 am
by travisc
Strange. Mine still seems to be stable on 10.9 using the 1.0.4 version of the plugin. My logs aren't showing a single read error on 8 sensors spread all around the house.
Re: Yosemite issues
PostPosted: Wed Sep 26, 2018 5:21 am
by c64
Would it be possible to reupload v1.0.4 please? (the dropbox link above is dead) I've just set this 1wire system up, and am also getting random results in terms of the number of sensors being detected. Many thanks!
Re: Yosemite issues
PostPosted: Wed Sep 26, 2018 7:51 am
by travisc
