Question re where to source State ID's
Tue Jan 26, 2021 1:02 am
hwitten offline
Coming to the party kinda late but I just replaced an aging DSC with a current panel and EnvisaLink 4. Have everything working. Am now working on email messaging and control page(s).
Can't quite wrap my head around State ID's, which I want/need, for use with BetterEmail, etc.
I will tackle it again tomorrow when fresh but thought I'd ask in case I'm just tired and missing something obvious as to where to find the State ID's for KeyPad, etc.
If it's written up already, my apologies. A pointer to same would be very much appreciated.
BTW... a BIG thank you for the Plugin.
Tue Jan 26, 2021 5:49 am
Re: Question re where to source State ID's
Within the Indigo UI, click on the device you're interested in. In the lower pane below the pane that displays the device details you will sometimes see a device states pane. You may have to scroll to see it (Apple has hidden scroll bars by default, so this is less than obvious). This pane is where you can see any custom states that a plugin device makes available.
The Better Email plugin supports what are called device substitutions. You reference these with the device ID and custom state name (it doesn't have to be a plugin device) using this structure:
%%d:12345678:stateName%%
or for variables:
%%v:12345678%%
(this works for variables, too.) Then simply refer to the substitution in your email message:
The value of the state is %%d:12345678:stateName%%.
To see all the states that a device has available, you can use a small bit of Python code:
indigo.server.log(str(dev.states))
(If it's not obvious, you need to replace 12345678 with the ID of your device)
Tue Jan 26, 2021 5:27 pm
hwitten offline
Thank you very much.
