Disarmed by user codes not showing up in Indigo
Mon Dec 11, 2017 8:07 pm
Monstergerm offline
Re: Disarmed by user codes not showing up in Indigo
Dang, I thought this has been solved. I really don't know what to say since everything works fine here. Can you try to stick with the master code for testing. I assume your system stores the master code under ID 40. In the config screen enter 40 in the User Code field and your name in the User Label field. Then fully arm the system and then disarm from the keypad with your master code. What does the Indigo log say? And what is your hardware?
