- Posted on
Wed Aug 30, 2017 12:20 pm
Monstergerm
offline
It should say something like this if you use the master code:
Alarm Panel Disarmed by User 40 'Joe and Jane'. (Partition 1 'Mainhouse')
I suspect you did not enter the user ID/name information correctly. User ID 40 is the master code. I assume you have the other user IDs, e.g. 01, 02 etc setup correctly on the DSC panel to be associated with their corresponding disarm codes.
Click on Show/Hide User Code Labeling.
Make sure there is no space between the comma when you enter the IDs and names.
In the User Code field enter for example: 40,01,02 (DO NOT ENTER THE ACTUAL CODES; JUST THE IDs)
In the User Label field enter: Joe and Jane,Homer,Bart
