Getting errors trying to connect to DSC panel through plugin
Tue Nov 29, 2016 10:31 am
mathur999 offline
Thanks for anyone who can help. I installed the latest version of Indigo 6.11 on a new MacOs X machine running el capitan and installed DSC plug in 2.09. It was working well on the previous machine. I am getting the following errors. Ay one have any ideas?
Thanks Arun
Starting plugin "DSC Alarm 2.0.9" (pid 17417)
DSC Alarm Log level preferences are set to "Normal".
Started plugin "DSC Alarm 2.0.9"
DSC Alarm Initializing communication at address: 192.168.1.145:4025
DSC Alarm Error Connection RX Error: connection failed ([Errno 54] Connection reset by peer)
DSC Alarm Error Connection TX Error: socket connection failed: [Errno 32] Broken pipe
Error plugin "DSC Alarm 2.0.9" (pid 17417) unexpectedly stopped -- restarting in 20 seconds
Tue Nov 29, 2016 1:26 pm
Re: Getting errors trying to connect to DSC panel through pl
What kind of module are you using on the DSC panel?
Tue Nov 29, 2016 5:23 pm
mathur999 offline
Envisalink 3.
Arun
Mon Dec 05, 2016 12:10 pm
Monstergerm offline
I have seen once in a while the RX Error: connection failed ([Errno 54] Connection reset by peer). The plugin then restarted and recovered without problem.
Are you still having the problem?
Sat Dec 17, 2016 9:02 am
mathur999 offline
Yes Still having problems. The following errors:
DSC Alarm Your plugin version, v2.0.9, is current.
Error plugin "DSC Alarm 2.0.9" (pid 1676) unexpectedly stopped -- restarting in 20 seconds
Error (client) _sendClosedConfigUi1() caught exception: PacketTargetNotConnectedError -- plugin DSC Alarm is not enabled
Sat Dec 17, 2016 10:35 am
Monstergerm offline
Is your Envisalink signed up with EyezOn?
Does it work properly there?
Sat Dec 17, 2016 6:59 pm
Oh is the old machine still running? The envisalink only supports one concurrent connection AFAIK (real shame really) so if the other machine is still connected it could be blocking it.
