Thermostat problem
Posted: Mon Oct 31, 2016 11:02 pm
Hi! I have been trying to set the temp on my thermostat, but i'm unable too.
At first i was getting errors that loops for ever, can stop the that loop, it goes on for ever.
Was able to pin down what was creating the error, but can't get the loop to stop even I fix the little bug in the code....
The error (029) is the in the Actions.xml file
vs
<Option value="h">Heat Setpoint</Option> changes to a uppercase H and was able to set temp but the loops remained.
And it's get even worse if you use increments because it continuously increases the temp... lol
Help would be appreciated.
- Code: Select all
2016-10-31 20:57:52.960 DSC Alarm Debug RX: 50009634
2016-10-31 20:57:52.961 DSC Alarm Debug ACK for cmd 096.
2016-10-31 20:57:52.967 DSC Alarm Debug RX: 50202932
2016-10-31 20:57:52.968 DSC Alarm Error IT-100/Envisalink Error (029): Unknown
2016-10-31 20:57:52.968 DSC Alarm Error Received system error after sending command, aborting.
2016-10-31 20:57:52.969 DSC Alarm Error Error changing thermostat setpoints, aborting adjustment.
2016-10-31 20:57:52.970 DSC Alarm Debug SensorNum = 1
2016-10-31 20:57:52.970 DSC Alarm Debug TX: 0951CF
<Action id="actionAdjustThermostat" deviceFilter="self.alarmTemp">
<Name>Adjust Thermostat</Name>
<CallbackMethod>methodAdjustThermostat</CallbackMethod>
<ConfigUI>
<Field type="menu" id="thermoAdjustWhich" defaultValue="h">
<Label></Label>
<List>
<Option value="H">Heat Setpoint</Option>
<Option value="C">Cool Setpoint</Option>
</List>
</Field>
<Field type="menu" id="thermoAdjustmentType" defaultValue="+">
<Label></Label>
<List>
<Option value="+">Increment by 1</Option>
<Option value="-">Decrement by 1</Option>
<Option value="=">Set to ...</Option>
</List>
</Field>
<Field type="textfield" id="thermoSetPoint" visibleBindingId="thermoAdjustmentType" visibleBindingValue="=">
<Label>Temperature:</Label>
</Field>
</ConfigUI>
</Action>
vs
<ConfigUI>
<Label></Label>
<List>
</List>
</Field>
<Label></Label>
<List>
</List>
</Field>
</Field>
</ConfigUI>
