Page 1 of 3
v2.0 Bugs
Posted:
Sun Aug 14, 2016 8:27 am
by durosity
Hi Travis/Monstergerm
So far so good with the new plugin, however i have found one issue that i thing is a bug.. before pressing * 7 1 would toggle a relay but now the virtual keypad does nothing when it's input. It still works fine from normal keypads. Any ideas on what we can do to correct that?
Re: v2.0 Bugs
Posted:
Sun Aug 14, 2016 1:43 pm
by durosity
Hmm actually the problem seems to be a bit more widespread than i originally thought. As soon as i try to do any input via the virtual keypad i start getting errors such as:
- Code: Select all
DSC Alarm Debug TX: 07110F9
DSC Alarm Debug RX: 50196
DSC Alarm Error IT-100/Envisalink Error: Received a command with a bad checksum
DSC Alarm Debug RX: 550203608141699
DSC Alarm Debug Alarm panel time is within 1 minute of actual time, no update necessary.
DSC Alarm Debug RX: 90100032 Date Time AUG 14/16 8:37p20
DSC Alarm Debug LCD Update, Line 1:' Date Time ' Line 2:'AUG 14/16 8:37p'
DSC Alarm Debug Updating state LCDLine1 for keypad on partition 0 to Date Time .
DSC Alarm Debug Updating state LCDLine2 for keypad on partition 0 to AUG 14/16 8:37p.
DSC Alarm Error Timed out after waiting for response to command 07110 for 3 seconds, retrying.
Which will then repeat itself for a few seconds before eventually returning to normal (at which point comms with the alarm returns to normal so things like zones opening results in the appropriate triggers occurring)
I've tried the following:
Deleting the control panel devices
New action groups to send the commands
Restarted the DSC alarm panel
Restoring back to previous version fixes errors
Disarming the alarm from a physical control panel has these errors:
- Code: Select all
DSC Alarm Debug RX: 90320FE
DSC Alarm Debug LED 'Armed' is 'off'.
DSC Alarm Debug Updating state LEDArmed for keypad on partition 1 to off.
DSC Alarm Debug RX: 90100032System Disarmed No Alarm Memory 00
DSC Alarm Debug LCD Update, Line 1:'System Disarmed ' Line 2:'No Alarm Memory '
DSC Alarm Debug Updating state LCDLine1 for keypad on partition 0 to System Disarmed .
DSC Alarm Debug Updating state LCDLine2 for keypad on partition 0 to No Alarm Memory .
DSC Alarm Debug RX: 90100032Secure or Arm System <>96
DSC Alarm Debug LCD Update, Line 1:'Secure or ' Line 2:' Arm System '
DSC Alarm Debug Updating state LCDLine1 for keypad on partition 0 to Secure or .
DSC Alarm Debug Updating state LCDLine2 for keypad on partition 0 to Arm System .
DSC Alarm Debug RX: 6531CF
DSC Alarm Error Timed out after waiting for response to command 0711*1# for 3 seconds, retrying.
DSC Alarm Debug TX: 0711*1#47
DSC Alarm Debug RX: 60903739
DSC Alarm Debug Zone number 37 Open.
DSC Alarm Debug RX: 6100252E
DSC Alarm Debug Zone number 25 Closed.
DSC Alarm Debug RX: 90100032 Date Time AUG 14/16 8:40p1A
DSC Alarm Debug LCD Update, Line 1:' Date Time ' Line 2:'AUG 14/16 8:40p'
DSC Alarm Debug Updating state LCDLine2 for keypad on partition 0 to AUG 14/16 8:40p.
DSC Alarm Debug RX: 61003731
DSC Alarm Debug Zone number 37 Closed.
For reference i'm using a PC5020 control panel with an IT100 connected to a PCI serial card in a Mac Pro
Re: v2.0 Bugs
Posted:
Mon Aug 15, 2016 10:57 pm
by travisc
Try updating the plugin again. I reinstated the old keypress routine.
Re: v2.0 Bugs
Posted:
Tue Aug 16, 2016 2:18 am
by durosity
Unfortunately same issue Travis.
Re: v2.0 Bugs
Posted:
Tue Aug 16, 2016 5:03 am
by durosity
Aha, correction.. it HAS worked however there's something else a miss. Before it was happening when any keypad button was pressed, now it's happening when the alarm is deactivated:
- Code: Select all
16 Aug 2016, 11:45:01
DSC Alarm Debug Received Send Keypress Action
DSC Alarm Debug TX: 0700C7
DSC Alarm Debug RX: 5000702C
DSC Alarm Debug ACK for cmd 070.
DSC Alarm Debug TX: 070^F5
DSC Alarm Debug RX: 9040012E
DSC Alarm Debug Beep Status
DSC Alarm Debug TX: 0707CE
DSC Alarm Debug RX: 90100032System Armed in Stay Mode <>94
DSC Alarm Debug LCD Update, Line 1:'System Armed ' Line 2:' in Stay Mode '
DSC Alarm Debug Updating state LCDLine1 for keypad on partition 0 to System Armed .
DSC Alarm Debug Updating state LCDLine2 for keypad on partition 0 to in Stay Mode .
DSC Alarm Debug TX: 0709D0
DSC Alarm Debug RX: 90400633
DSC Alarm Debug RX: 55011440816169A
DSC Alarm Debug RX: 6551D1
DSC Alarm Debug Updating state state for keypad on partition 1 to disarmed.
DSC Alarm Debug Updating state ArmedState for keypad on partition 1 to disarmed.
Trigger Alarm: State Changes
DSC Alarm Debug Updating state PanicState for keypad on partition 0 to none.
DSC Alarm Debug Updating state ReadyState for keypad on partition 1 to ready.
DSC Alarm Debug Updating state LEDReady for keypad on partition 1 to on.
DSC Alarm Debug Updating state LEDBypass for keypad on partition 1 to off.
DSC Alarm Debug RX: 90311FE
DSC Alarm Debug LED 'Ready' is 'on'.
DSC Alarm Debug RX: 9034000
DSC Alarm Debug LED 'Bypass' is 'off'.
DSC Alarm Debug RX: 7501004091
DSC Alarm Alarm Panel Disarmed by User 40 'Master'. (Partition 1 'House')
DSC Alarm Debug <<-- entering triggerEvent: eventAlarmDisarmed
Trigger Alarm: Disarmed
Action Group Lighting: Mockupancy Off
Action Group Heating: Set All General
Ignored device "Gym - Main Light" action request (communication is disabled)
DSC Alarm Debug ID: speakTextDisarmed
Z-Wave sent "Bedroom 1 - Claire's Light" off
Z-Wave sent "Ensuite - Light" off
Z-Wave sent "Study - Desk Light" off
Z-Wave sent "Landing - Light" off
Z-Wave sent "Bathroom - Light" off
Schedule Alarm: Disarmed (delayed action)
Autolog Stella-Z Heat setpoint altered to 20.0 for 'Lounge - Heating Control'
Autolog Stella-Z Heat setpoint altered to 18.5 for 'Dining - Heating Control'
Autolog Stella-Z Heat setpoint altered to 14.0 for 'Utility - Heating Control'
Autolog Stella-Z Heat setpoint altered to 14.0 for 'Bathroom - Heating Control'
DSC Alarm Debug RX: 6501CC
DSC Alarm Debug Partition 1 Ready
DSC Alarm Debug RX: 90100032System is Ready to Arm A8
DSC Alarm Debug LCD Update, Line 1:'System is ' Line 2:'Ready to Arm '
DSC Alarm Debug Updating state LCDLine1 for keypad on partition 0 to System is .
DSC Alarm Debug Updating state LCDLine2 for keypad on partition 0 to Ready to Arm .
Autolog Stella-Z Heat setpoint altered to 14.0 for 'Bedroom 2 - Heating Control'
Autolog Stella-Z Heat setpoint altered to 14.0 for 'Study - Heating Control'
Autolog Stella-Z Heat setpoint altered to 10.0 for 'Gym - Heating Control'
Autolog Stella-Z Heat setpoint altered to 14.0 for 'WC - Heating Control'
DSC Alarm Debug RX: 90100032 Date Time AUG 16/16 11:44a1B
DSC Alarm Debug LCD Update, Line 1:' Date Time ' Line 2:'AUG 16/16 11:44a'
DSC Alarm Debug Updating state LCDLine2 for keypad on partition 0 to AUG 16/16 11:44a.
DSC Alarm Error Resent command 0711*1# 3 times with no success, aborting.
Re: v2.0 Bugs
Posted:
Tue Aug 16, 2016 5:24 am
by durosity
Also trying to set a bypass causes similar issues:
WebServer request to execute "iPad: Devices: Security" control #168 from 193.128.190.102
DSC Alarm Received Zone Bypass Action for Zone 'Ensuite - Window Sensor' in Partition 1 'House'.
DSC Alarm Debug TX: 0711*130#AA
Re: v2.0 Bugs
Posted:
Tue Aug 16, 2016 6:47 am
by travisc
Oops. I used a == instead of 'is'. I've been away from Python too long. The error you saw on disarm should be fixed.
The new bypass actions are only available to the Envisalink devices right now. That 07110 command you see causing trouble is only available on those devices. It's required for the plugin to get a list of the bypassed zones so it can manage them properly.
You should still be able to bypass zones manually using the Send Keypress action to send the correct key presses.
We may work around this in the future if there's an elegant solution.
Travis
Re: v2.0 Bugs
Posted:
Tue Aug 16, 2016 9:16 am
by durosity
Hehe, i think i might have to lock you up down in the basement with Jay for some hardcore Python sessions!
I'll test it out when i get home.
Bypass would be awesome if it can be done.. it's something i've been hoping for for a long long long time.
Re: v2.0 Bugs
Posted:
Tue Aug 16, 2016 11:24 am
by travisc
I'm not sure if it'll work with the IT-100. The plugin would have no way to know for sure which zones are already in a bypassed state.
You should be able to bypass zones now though, just create a Keypress action that sends the right key sequence. Do the same to disable the bypass. Then just trigger those actions.
Does that not work?
Re: v2.0 Bugs
Posted:
Tue Aug 16, 2016 12:20 pm
by durosity
I've never tried it, but I'm going to guess there's not going to be any way to get a status showing it as bypassed (WAF requires visual feedback
Perhaps I'll just need to upgrade to an envisalink. (On a side note is there any discernible downsides to the envisalink vs it100?)
Re: v2.0 Bugs
Posted:
Tue Aug 16, 2016 1:02 pm
by durosity
Just tested 2.02, still getting errors on disarm:
Re: v2.0 Bugs
Posted:
Tue Aug 16, 2016 1:41 pm
by travisc
Oh man. Found one more place where it needed the exception. Can you please try one more time. It's 2.0.3 now.
Re: v2.0 Bugs
Posted:
Tue Aug 16, 2016 1:49 pm
by durosity
I'll give it a proper full on test this weekend but so far so good.
Re: v2.0 Bugs
Posted:
Fri Aug 19, 2016 4:47 pm
by durosity
I've found one other issue.. i'm not sure if it's a problem or a feature. When disarming using a keyswitch i get " DSC Alarm Alarm Disarmed by Special Opening (Partition 1 'House')" in the event log. I have a trigger setup for alarm state disarming which prior to v2 worked fine, but now doesn't seem to get triggered. I've noticed there's now three events for triggers, Alarm Disarmed (Any partition), And two for Alarm Disarmed by user code. The trigger is using Alarm Disarmed (any partition) but still fails to fire.
Re: v2.0 Bugs
Posted:
Fri Aug 19, 2016 8:10 pm
by Monstergerm
The plugin prior to version 2 had two triggers:
Alarm Disarmed and Alarm Disarmed by User Code. Those did not change but they were renamed to add (any partition). Do they get triggered when you disarm from the keypad?
A new trigger was added to monitor if Alarm was disarmed by user code in a particular partition.
V2 of the plugin also added code to monitor special openings, which you see in your log. I assume you turned log level 2 on. This currently does not trigger anything but it would be easy to change this.
I don’t have a keyswitch so I cannot test which of the TPI commands are being sent (or not sent) when you press that switch. Can you turn debug on and post what is being transmitted.
