v2.0 Bugs
Sun Sep 11, 2016 11:16 am
whmoorejr offline
Re: v2.0 Bugs
SOLVED!!!
Travis, You can categorize my "Bug" as user error. Your plugin is still rock solid.
matt (support) wrote:
I'm not sure exactly how that error is occurring. Choose the Indigo 6->About Indigo... menu item – what versions does it show for both the Indigo client and server? Are they the same?
:D
That did it. I had 6.1.7 on the client and 6.1.10 on the server. I usually don't look at the version... I just select the "Check for updates" which said, while running 6.1.7, You have the latest version. So I downloaded 6.1.10, installed and presto... no more errors. I updated a device, changed a trigger, everything is visible again.
Thanks to all of you that helped me work through this.
Matt.... what made you suspect the inconsistency in versions? (Just so I know what to look for in the future if I run into weirdness)
Mon Sep 12, 2016 7:14 am
Re: v2.0 Bugs
The only way I figured that error could occur would be if there was a client/server mismatch.
When we have changes that break compatibility between the client and server we are supposed to update a magic internal protocol version number in Indigo, which causes Indigo to refuse (and show an error) if you try to connect to a mismatched server from a client. I forgot to bump that protocol version number the last time I made an incompatible change, so Indigo allowed the connection even though it was doomed to fail.
Thu Oct 27, 2016 5:25 pm
durosity offline
Re: v2.0 Bugs
Just found another little buglet hiding away.
I've just deleted a DSC zone i no longer need. Now every time anything causes activation of a zone i'm getting the following error:
  DSC Alarm Error                 Error in plugin execution runConcurrentThread:
  File "plugin.py", line 2096, in runConcurrentThread
  File "plugin.py", line 1147, in readPacket
  File "plugin.py", line 1703, in updateZoneState
  File "plugin.py", line 1670, in updateZoneGroup
KeyError: key id 1164781791 not found in database
  DSC Alarm Error                 plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
And of course ID 1164781791 is the device i just deleted. Alas i can't seem to correct the issue without restoring a backup of the DB.. so far i've tried:
Deleting the prefs file
creating a new device and assigning the old zone to it
reloading the plugin
restarting Indigo
Thu Oct 27, 2016 5:39 pm
durosity offline
Re: v2.0 Bugs
Ah wait found it.. it was a zone group that referenced it. Still would be nice if it validated the info itself :D
