enable chime
Tue Aug 02, 2016 11:35 am
dtich offline
enable chime
hi travis (and/or anyone else who may know!),
is there a way in your plugin to enable/disable the dsc door chime function? or, is this a simple keypress seq i can do with your plugin?
i'd like to enable the chime at night.
thanks!
Tue Aug 02, 2016 11:43 am
nlagaros offline
Re: enable chime
Try *4
Tue Aug 02, 2016 12:33 pm
dtich offline
Re: enable chime
yes, am trying that. thanks.
hoping that there is a discrete command for 'chime on' 'chime off'.. anybody know? or is it only a toggle?
thanks for the reply.
Tue Aug 02, 2016 2:38 pm
nlagaros offline
Re: enable chime
To my knowledge it is only a toggle. You could always check the current state before taking the action.
Tue Aug 02, 2016 3:08 pm
dtich offline
Re: enable chime
i see i can access chime enable state from a trigger dialogue, but can i script it? i'd rather write a script to read it when it changes and make decisions, than have various indigo triggers for each state. do you happen to know if this is addressable via AppleScript?
thanks again.
Tue Aug 02, 2016 3:25 pm
dtich offline
Re: enable chime
also, i get this when sending command '*4':
 IT-100/Envisalink Error (027): API Invalid Characters in Command
  DSC Alarm Error                 Received system error after sending command, aborting.
i am using a pc-5401 i believe. 10 years at least now. does this board not do this command?
thx
edit: yes, i don't see the chime commands in the 5401 install man. hm. would this be avail on the envisalink 4?
Tue Aug 02, 2016 3:54 pm
nlagaros offline
Re: enable chime
I have an Envisalink 3 and it works fine.
Tue Aug 02, 2016 4:08 pm
dtich offline
Re: enable chime
ok, thanks for that. maybe i'll change out the board.
dt.
Thu Aug 25, 2016 10:46 am
Monstergerm offline
Re: enable chime
v2.0.6 of the plugin now has enable/disable keypad chime commands that monitor the chime state and therefore are not just toggles. As far as I know they only work with Envisalink modules since the other interfaces do not send chime state update commands.
