[SOLVED]: log error after install of Indigo update 6.1.7
Wed Mar 09, 2016 1:07 pm
jens offline
error in log after install of latest Indigo update 6.1.7 some one that can help :(
mar 2016 20:00:30
DSC Alarm Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 1521, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/DSC Alarm.indigoPlugin/Contents/Server Plugin/indigoPluginUpdateChecker.py", line 109, in checkVersionPoll
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/DSC Alarm.indigoPlugin/Contents/Server Plugin/indigoPluginUpdateChecker.py", line 114, in checkVersionNow
File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 190, in debugLog
<type 'exceptions.AttributeError'>: 'logger' object has no attribute 'debug'
DSC Alarm Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
//Jens
Wed Mar 09, 2016 5:26 pm
Seeker offline
Re: error in log after install of latest Indigo update 6.1.7
I'm getting the same error after the indigo upgrade. But I haven't noticed any DSC functions not working.
Wed Mar 09, 2016 8:59 pm
A change we made to Indigo 6.1.7 is causing a conflict with that plugin. I've fixed the change in my git fork of the plugin which you can download here:
https://github.com/mbendiksen/DSC-Alarm ... master.zip
We'll get that change merged back into the main report shortly, but in the meantime you can download the fix above.
Wed Mar 09, 2016 9:58 pm
Korey offline
Thanks for the quick fix Matt!!
Korey
Wed Mar 09, 2016 11:54 pm
jens offline
Thanks Matt
Sent from my iPhone 6 using Tapatalk
Sun Apr 17, 2016 11:43 am
dstrickler offline
This worked perfectly for me too - thanks Matt! :D
Dave
