Unrecognized command received (Cmd:659 Dat:1 Sum:213)
Mon Jul 14, 2014 7:05 pm
Pierre offline
I have this error since the installation. Any help to correct this Unrecognized command received would be appreciated.
Pierre
Started plugin "DSC Alarm 1.5.3"
DSC Alarm Debug getConfiguration start
DSC Alarm Debug Configuration read successfully
DSC Alarm Debug runConcurrentThread called
DSC Alarm Debug STATE: Startup
DSC Alarm Initializing communication at address: 192.168.2.26:4025
DSC Alarm Debug Received login request
DSC Alarm Debug ACK for cmd 005.
DSC Alarm Connected to Envisalink.
DSC Alarm Enabling Time Broadcast
DSC Alarm Debug ACK for cmd 056.
DSC Alarm Time Broadcast enabled.
DSC Alarm Pinging the panel to test communication...
DSC Alarm Debug ACK for cmd 000.
DSC Alarm Ping was successful.
DSC Alarm Requesting a full state update.
DSC Alarm Debug ACK for cmd 001.
DSC Alarm State update request successful, initialization complete, starting normal operation.
DSC Alarm Debug Zone number 1 Closed.
DSC Alarm Debug Zone number 2 Closed.
DSC Alarm Debug Zone number 3 Closed.
DSC Alarm Debug Zone number 4 Closed.
DSC Alarm Debug Zone number 5 Closed.
DSC Alarm Debug Zone number 6 Closed.
DSC Alarm Debug Zone number 7 Closed.
DSC Alarm Debug Zone number 8 Closed.
DSC Alarm Debug Zone number 9 Closed.
DSC Alarm Debug Zone number 10 Closed.
DSC Alarm Debug Zone number 11 Closed.
DSC Alarm Debug Zone number 12 Closed.
DSC Alarm Debug Zone number 13 Closed.
DSC Alarm Debug Zone number 14 Closed.
DSC Alarm Debug Zone number 15 Closed.
DSC Alarm Debug Zone number 16 Closed.
DSC Alarm Debug Zone number 17 Closed.
DSC Alarm Debug Zone number 18 Closed.
DSC Alarm Debug Zone number 19 Closed.
DSC Alarm Debug Zone number 20 Closed.
DSC Alarm Debug Zone number 21 Closed.
DSC Alarm Debug Zone number 22 Closed.
DSC Alarm Debug Zone number 23 Closed.
DSC Alarm Debug Zone number 24 Closed.
DSC Alarm Debug Zone number 25 Closed.
DSC Alarm Debug Zone number 26 Closed.
DSC Alarm Debug Zone number 27 Closed.
DSC Alarm Debug Zone number 28 Closed.
DSC Alarm Debug Zone number 29 Closed.
DSC Alarm Debug Zone number 30 Closed.
DSC Alarm Debug Zone number 31 Closed.
DSC Alarm Debug Zone number 32 Closed.
DSC Alarm Debug Zone number 33 Closed.
DSC Alarm Debug Zone number 34 Closed.
DSC Alarm Debug Zone number 35 Closed.
DSC Alarm Debug Zone number 36 Closed.
DSC Alarm Debug Zone number 37 Closed.
DSC Alarm Debug Zone number 38 Closed.
DSC Alarm Debug Zone number 39 Closed.
DSC Alarm Debug Zone number 40 Closed.
DSC Alarm Debug Zone number 41 Closed.
DSC Alarm Debug Zone number 42 Closed.
DSC Alarm Debug Zone number 43 Closed.
DSC Alarm Debug Zone number 44 Closed.
DSC Alarm Debug Zone number 45 Closed.
DSC Alarm Debug Zone number 46 Closed.
DSC Alarm Debug Zone number 47 Closed.
DSC Alarm Debug Zone number 48 Closed.
DSC Alarm Debug Zone number 49 Closed.
DSC Alarm Debug Zone number 50 Closed.
DSC Alarm Debug Zone number 51 Closed.
DSC Alarm Debug Zone number 52 Closed.
DSC Alarm Debug Zone number 53 Closed.
DSC Alarm Debug Zone number 54 Closed.
DSC Alarm Debug Zone number 55 Closed.
DSC Alarm Debug Zone number 56 Closed.
DSC Alarm Debug Zone number 57 Closed.
DSC Alarm Debug Zone number 58 Closed.
DSC Alarm Debug Zone number 59 Closed.
DSC Alarm Debug Zone number 60 Closed.
DSC Alarm Debug Zone number 61 Closed.
DSC Alarm Debug Zone number 62 Closed.
DSC Alarm Debug Zone number 63 Closed.
DSC Alarm Debug Zone number 64 Closed.
DSC Alarm Unrecognized command received (Cmd:659 Dat:1 Sum:213)
DSC Alarm Debug Partition 2 Busy.
DSC Alarm Debug Partition 3 Busy.
DSC Alarm Debug Partition 4 Busy.
DSC Alarm Debug Partition 5 Busy.
DSC Alarm Debug Partition 6 Busy.
DSC Alarm Debug Partition 7 Busy.
DSC Alarm Debug Partition 8 Busy.
DSC Alarm Trouble Status Restore (LED OFF). (Partition 1)
DSC Alarm Trouble Status Restore (LED OFF). (Partition 2)
DSC Alarm Trouble Status Restore (LED OFF). (Partition 3)
DSC Alarm Trouble Status Restore (LED OFF). (Partition 4)
DSC Alarm Trouble Status Restore (LED OFF). (Partition 5)
DSC Alarm Trouble Status Restore (LED OFF). (Partition 6)
DSC Alarm Trouble Status Restore (LED OFF). (Partition 7)
DSC Alarm Trouble Status Restore (LED OFF). (Partition 8)
Mon Jul 14, 2014 8:12 pm
Re: Unrecognized command received (Cmd:659 Dat:1 Sum:213)
According to the protocol guide (http://homeseer.com/pdfs/DSC/29007363R0 ... _guide.pdf):
Keypad Blanking
659 (36, 35, 39h)
1 Partition 1-8 (31-38h)
This command indicates that Keypad Blanking has occurred on a partition
Sounds like the plugin doesn't implement that command.
I also found this on another board:
Update: I modified the keypad blanking setting (section 016 option 3) to disable it (disabled is the default, but I enabled it during initial config as I felt it would reduce battery consumption). Now the plug-in works as expected for Arming/Disarming.
So the workaround solution is to ensure Keypad Blanking is Disabled.
Tue Jul 15, 2014 4:16 pm
Pierre offline
Thanks, I will check this the keypad blanking configuration
Regards
