However, I see that the alarm panel is sending command 655 when you disarm with the key fob (I assume you disarmed after the system was fully armed - not still in exit delay). If you are familiar with python programming we can add a line to the code to generate a log message for this event.
Somewhat familiar with python but far from expert
Would I be able to build a trigger action on that 655?
I use the key fob to disarm from the car upon returning home and look for confirmation on Apple Watch before opening garage door. I get that via Envisalink but much nicer with an iMessage via Indigo.
