Recurring Error
Tue Oct 02, 2018 4:58 am
LSpad offline
Recurring Error
Hi there,
Smartphone Radar has been working brilliantly on my server for over a year, but it has just recently started throwing the following errors.
File "plugin.py", line 86, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Smartphone Radar.indigoPlugin/Contents/Server Plugin/iPresence.py", line 609, in startComm
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Smartphone Radar.indigoPlugin/Contents/Server Plugin/iPresence.py", line 402, in checkPhoneTimers
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Smartphone Radar.indigoPlugin/Contents/Server Plugin/iPresence.py", line 377, in incPhoneLastSeenTimer
AttributeError: 'iPresence' object has no attribute 'minutesTillAway'
Smartphone Radar Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
The loop continues indefinitely and I've ended up disabling the plugin until I can get it resolved. Do you have any suggestions on how I can fix things?
Many thanks
Luke
Tue Oct 02, 2018 7:50 am
travisc offline
Re: Recurring Error
Have you tried opening the plugin's config and hitting OK again to save it?
Mon Oct 08, 2018 7:34 am
LSpad offline
Re: Recurring Error
Many thanks! This solved the problem!
