INSTEON Thermostats
Mon May 21, 2018 3:45 pm
Re: INSTEON Thermostats
We don't.
Sun Sep 13, 2020 1:53 pm
Frozenman offline
I just purchased a new Insteon 2441TH. I replaced an existing 5-wire thermostat with the new one. I double checked the proper color coding at the AC end of the 5-wire cable. Keep in mind that the previous thermostat was working fine.
The new thermostat does not light up, the time does not display - the screen is totally blank.
Any advise for further troubleshooting?
I replaced the original thermostat since I wanted the AC to work :) which it now does...
I'd be open to other suggestions for an Indigo-controllable thermostat.
thanks!
Sun Sep 13, 2020 4:21 pm
ELWOOD offline
The insteon T-stat needs both the 24 com and 24R connection from the 24 volt transformer in your heating system. If the old T-stat had a battery in it it probably does not have the 24com wire. If you have a volt meter check that you have 24 volts ac at the top two terminals. (24com, 24R). If there is no voltage that is your problem,
Elwood
Mon Sep 14, 2020 5:59 am
Frozenman offline
thanks
On the old thermostat, the blue wire is connected to RC and the red wire is connected to RH. I don't measure any voltage across those 2 wires :(
I'll go look at how they are connected at the AC end -
thanks for the pointer
Sun Sep 20, 2020 9:56 pm
Frozenman offline
Well as it turns out while the thermostat end had all 5 wires, the ac end was non-standard. The blue wire was connected to the R terminal on the air handler. So some rewiring was indeed required. I think I have it figured out. Thanks for the pointers.
