Smartenit EZFlora and Rainbee8
Wed Jun 27, 2018 6:08 pm
Re: Smartenit EZFlora
Sounds like it doesn't really act like an EZFlora, unfortunately. I'm going to email you with some additional questions / steps.
Wed Jun 27, 2018 7:22 pm
jphauck offline
Well the device figured itself out after that - i sent the logs to you. I am going to put the unit where th adapter for the heads and try it out.
Jim H.
Concord, CA
Wed Jun 27, 2018 7:48 pm
jphauck offline
And the old unit now came back to life but it still can not figure itself out.
Jim H.
Concord, CA
Wed Jul 25, 2018 2:59 am
agame offline
Anyone using the z-connect valve with indigo?
I have one included on an old Vera ... it works perfectly.
http://www.smartliving.com.au/zconnect- ... -15mm.html
It isn’t an irrigation controller but works well.
Wed Jun 29, 2022 12:00 pm
pgershon wrote:
Is the GoControl WI15VZ-1 Z-Wave Irrigation Controller supported by Indigo?
This is a reply to a very old post, but FYI Indigo 2022.1.2 is now available and includes beta support for the LinearLinc / GoControl Irrigation Controller (WI15VZ).
Sun Oct 23, 2022 5:47 pm
MattDinOC offline
Re: Smartenit EZFlora and Rainbee8
Just a quick note to share my experience replacing an EZFlora with 2 ZEN17 general-purpose Z-Wave relay modules:
viewtopic.php?f=58&t=25848&p=214212#p214212
It's not super practical for applications where you need to control lots of valves, but since I only have 4, this worked out pretty well for me.
Cheers,
Matt
Thu Apr 13, 2023 4:31 pm
sgtwicki offline
I haven't payed attention to my EZRain (EZFlora) over the winter. When I went to go set it up today, I noticed my Indigo 2022.2 now thinks the device is an IR-Linc Transmitter. I tried deleting the device and adding it again, but I get the same results.
Here is the event log when re-adding the device:
PowerLinc Linking - entered discovery linking mode (240 seconds)
PowerLinc Linking - received module button pressed from 01.DB.EE
PowerLinc Linking - sending engine version request to 01.DB.EE
PowerLinc Linking - received engine version 01 from 01.DB.EE
PowerLinc Linking - sending id request for device information to 01.DB.EE
PowerLinc Linking - received id request response from 01.DB.EE
PowerLinc Linking - initializing remote device "new device" (address 01.DB.EE, firmware version 90)
PowerLinc Linking - initialize complete
PowerLinc Linking - syncing remote device "new device" (address 01.DB.EE, firmware version 90)
PowerLinc Linking - syncing of this device not possible remotely (skipping)
PowerLinc Linking - sync complete
PowerLinc Linking - syncing PowerLinc links (address 52.19.DE)
PowerLinc Linking - . . adding: INSTEON plc link to controller 01.DB.EE, flags 03, group 01, data 00 00 FF
PowerLinc Linking - PowerLinc links updated
Thu Apr 13, 2023 4:48 pm
It has gotten into a bad state (this happens with the EZFlora sometimes, unfortunately). Unplug it from the wall for a couple of minutes then try re-syncing it again.
Thu Apr 13, 2023 5:01 pm
sgtwicki offline
Yep, that seems to have been the case.
I factory defaulted it, then re-added it. Added/synced fine this time !
