Aeon Labs Key Fob Remote (DSA22)
Sat May 11, 2013 6:16 pm
This thread is for discussing the Aeon Labs (Aeotec) Minimote remote control.
Device details
How to use with Indigo
Tue Sep 03, 2013 11:42 am
Re: Aeon Labs Key Fob Remote (DSA22)
Have it linked to indigo, But the only info I have is battery level - no reaction to any button
did:
1. remove zwave stick from mac
2. press blue button
3. put pin into key fob learn hole
4. green light blinks .. key fob
5. blue light (zwavestick) blinks.. press button
6. reconnect to indigo mac
7. add new device / wave / use node .. pick key fob .. successful.
finish.
no reaction to any button.
What am I doing wrong. whats missing?
Do I have to press one of the 4 buttons.. do it for all 4?
here the log filein indigo:
Indigo Z-Wave Version: 1.0.84
Node ID: 8
Model: Key Fob (DSA22)
Model ID: 00010016
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 2.78
Application Version: 1.12
Model Definition Version: 3
Library Type: 2
Class Name: Portable Remote Controller
Class Hierarchy: 01 : 01 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 70v1 72v1
Features: battery, beaming, waking
Neighbors: - none -
Associations: 1:[1]
Config Values: 250:0
Tue Sep 03, 2013 12:29 pm
Did you follow the how to use with Indigo wiki mentioned above? It sounds like you haven't turned on the Enable scene mode for all buttons option yet.
Tue Sep 03, 2013 12:41 pm
... just read the manual ... works now thanks and sorry for asking stupid questions
ps in my defense I did not find the indigo manual.. just looked at the discussions, did a search there. anyway thanks
Tue Sep 03, 2013 12:51 pm
No problem at all. There is lots of information on the site so it is easy to overlook something...
Thu Jun 26, 2014 6:16 am
gpbell offline
I am a new Indigo user and trying to set up a late Zwave system. I am having trouble configuring an Aeotec DSA22 4 button remote. I have associated it with the Z Stick and added it to Indigo. I have ticked the 'Enable scene mode for all buttons', held down one of the buttons and saved, however I am still unable to see anything other than battery level when I try to set up a trigger. Can someone please point out what I am doing wrong?
Greg
Thu Jun 26, 2014 7:21 am
What does the Event Log show (if anything) when you press a button on it?
If it shows nothing, then re-sync it again and copy/paste the Event Log results of the sync.
Sat Jun 28, 2014 4:20 am
gpbell offline
Hi Matt,
The event log showed nothing, so I resented, and here is the log.
28 Jun 2014 8:19:02 pm
Z-Wave Syncing - started for device "Key Fob - Greg"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 02 01 01 7B
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E
Z-Wave Debug . . getNodeNeighbors: nodeId 002, neighbors: - none -
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 02 04 34 AB
Z-Wave Debug RCVD requestNodeInfo: 01 06 00 49 81 00 00 31
Z-Wave Debug RCVD requestNodeInfo: failed (module asleep or doesn't support command)
Z-Wave Error Syncing - failed
Z-Wave Error No response from "002 - Key Fob - Greg". Module might be asleep, or is unreachable.
Z-Wave Debug RCVD sceneActivateCmd: 01 0A 00 04 00 02 04 2B 01 02 FF 20
Z-Wave Debug . . sceneActivateCmd: node 002, scene: 2
Z-Wave received "Key Fob - Greg" scene 2
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 02 04 35 AA
Z-Wave Debug RCVD requestNodeInfo: 01 12 00 49 84 02 0C 01 01 01 86 72 70 80 84 85 EF 2B 26 C8
Z-Wave Debug . . requestNodeInfo: node 002, combined class list: 20v1 80v1 84v1 85v1 86v1 70v1 72v1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 02 02 72 04 05 36 A0
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 02 08 72 05 00 86 00 01 00 16 19
Z-Wave Debug . . requestManufactureInfo: node 002, manufacturerId 0086, productId 00010016
Z-Wave Debug . . requestManufactureInfo: Aeon Labs, Key Fob (DSA22)
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Key Fob (DSA22) - 00010016
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 02 02 86 11 05 37 40
Z-Wave Debug RCVD requestVersInfoGen: 01 0D 00 04 00 02 07 86 12 02 02 4E 01 0E 26
Z-Wave Debug . . requestVersInfoGen: node 002, protoVers 2.78, appVers 1.14
Z-Wave Syncing - retrieved protocol version 2.78, app version 1.14
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 02 03 86 13 84 05 38 CB
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 02 04 86 14 84 02 E3
Z-Wave Debug . . requestVersInfoCmdClass: node 002, class command 84 using version 2
Z-Wave Debug . . requestVersInfoCmdClass: node 002, combined class list: 20v1 80v1 84v2 85v1 86v1 70v1 72v1
Z-Wave Syncing - retrieved class hierarchy: Controller : Portable Controller : Portable Remote Controller (01 : 01 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 70v1 72v1
Z-Wave Debug SENT requestWakeInterval: 01 09 00 13 02 02 84 05 05 39 58
Z-Wave Debug RCVD requestWakeInterval: 01 0C 00 04 00 02 06 84 06 00 38 40 01 08
Z-Wave Debug . . requestWakeInterval: node 002, interval 240 minutes, wakeTarget 001
Z-Wave Syncing - retrieved wake interval of 240 minutes
Z-Wave Debug SENT setWakeInterval: 01 0D 00 13 02 06 84 04 00 38 40 01 05 3A 23
Z-Wave Syncing - device "002 - Key Fob - Greg" wake interval changed to 240 minutes
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 02 02 85 05 05 3B 5B
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 02 03 85 06 01 71
Z-Wave Debug . . requestAssociationGroupCount: node 002, group count: 1
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 02 03 85 02 01 05 3C 58
Z-Wave Debug RCVD requestAssociations: 01 0C 00 04 00 02 06 85 03 01 05 00 01 70
Z-Wave Debug . . requestAssociations: node 002, group: 1, num associations: 1, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 002, group: 1, associations: [1]
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 02 03 70 05 FA 05 3D 50
Z-Wave Debug RCVD requestConfigVal: 01 0E 00 04 00 02 08 70 06 FA 01 01 00 00 00 73
Z-Wave Debug . . requestConfigVal: node 002, parm index 250, value 1 (size 1)
Z-Wave Syncing - retrieved Enable scene mode for all buttons is true
Z-Wave Debug . . requestConfigVal: node 002, combined config vals: 250:1
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 02 02 80 02 05 3E 5C
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 02 03 80 03 64 14
Z-Wave Debug . . requestBatteryLevel: node 002, level 100
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - complete
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 02 02 80 02 05 3F 5D
Z-Wave Debug terminatingSyncUI
Z-Wave received "002 - Key Fob - Greg" status update battery level 100%
Sat Jun 28, 2014 4:57 am
But it looks like the Event Log did show something when you pressed/held a button to wake it:
Sat Jun 28, 2014 5:12 am
gpbell offline
That looks correct, however when I tried to press each of the four buttons I received no response. Holding down each of the four buttons gave me this following log. Note that only 2 of the buttons registered?
28 Jun 2014 9:09:10 pm
Z-Wave Debug RCVD sceneActivateCmd: 01 0A 00 04 00 02 04 2B 01 06 FF 24
Z-Wave Debug . . sceneActivateCmd: node 002, scene: 6
Z-Wave received "Key Fob - Greg" button 3 held down
Z-Wave Debug RCVD sceneActivateCmd: 01 0A 00 04 00 02 04 2B 01 01 FF 23
Z-Wave Debug . . sceneActivateCmd: node 002, scene: 1
Z-Wave received "Key Fob - Greg" button 1 pressed
Not sure what is going on?
I assume that when I try and assign a trigger for this device I should be able to select something other than battery level?
Sun Jun 29, 2014 10:18 am
In regards to the Trigger, yes, you can select button specific triggers. Instead of selecting the Device State Changed type though you need to select the type Z-Wave Event because you want to trigger on a specific incoming Z-Wave command (and not a generic state change).
I still don't understand what is going on with which buttons are working/not working though. In the above Event Log snippet you included above it looks like the button 1 press and button 3 held down commands were received. But you aren't seeing any commands from any of the other buttons? And you are using it within close range of the Z-Stick? You might try excluding it from the Z-Stick and re-adding it (then re-syncing it with Indigo). Perhaps it is just in a bad state. The other possibility is it is malfunctioning, but I've never heard of one failing like this before.
Sun Jan 11, 2015 12:02 am
papamac offline
New Aeotec Key Fob Remote (ZW088-A)
I have used the old Aeotec Key Fob Remote (DSA22) successfully for over a year now. I recently purchased two of the new Gen 5 Z-Wave key fobs (ZW088-A) and things are not so good. The setup and define/sync are pretty much the same as the old one, but I am unable to define triggers for the individual buttons. I can create a trigger for the key fob on a Z-Wave command received, but the only options available in the pull-down menu are "Battery Level Update" or "Any Command". On the older key fob, I can select "Button 1 Pressed", "Button 1 Held", and so on. It seems that Aeotec did something with the new key fob that is not compatible with Indigo.
I am enclosing a segment of the Indigo Event Log showing a define/sync for the new key fob and a sequence of button pressings. Note at the end that Indigo does respond to the individual buttons both when pressed and when held. The only problem is defining triggers to respond to those received Z-Wave commands.
Can anyone help with this? Do we need a software fix and a new Indigo release?
David Krause
Z-Wave received "linda-keyfob" scene 2
Z-Wave Syncing - started for device "linda-keyfob"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Portable Remote Controller - 01010058
Z-Wave Syncing - retrieved protocol version 3.83, app version 1.02
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 70v1 72v1 73v1 59v1 5Av1 5Ev1
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "064 - linda-keyfob" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved battery level of 92%
Z-Wave received "064 - linda-keyfob" status update battery level 92%
Jan 10, 2015, 9:30:14 PM
Z-Wave received "linda-keyfob" scene 1
Z-Wave received "linda-keyfob" scene 3
Z-Wave received "linda-keyfob" scene 4
Z-Wave received "linda-keyfob" scene 5
Z-Wave received "linda-keyfob" scene 6
Z-Wave received "linda-keyfob" scene 7
Z-Wave received "linda-keyfob" scene 8
Mon Jan 12, 2015 5:14 pm
Hi David,
I had to add the new model ID to Indigo. I've done so, but I don't have a gen 5 key fob to test it against. If you want to try it before we release the next version of Indigo then contact us.
Mon Jan 12, 2015 5:28 pm
papamac offline
Thanks Matt. I'd be happy to test it for you. Let me know where to get the update.
David
Mon Jan 12, 2015 5:52 pm
Send me an email and I'll forward the info on to you.
