Aeon Labs Key Fob Remote (DSA22)
Fri Jan 23, 2015 1:40 am
PME999 offline
Re: Aeon Labs Key Fob Remote (DSA22)
Hello Matt
I've recently purchased the news key fob also and I have the same problem. Zwave event are only battery level update or any command.
The settings of the device after inclusion doesn't allow me to set scene mode.
My question is did you do the testings and if yes does the device can work with a specific action or do I have to wait the next indigo update (in this case if you can give me approx. schedule)
Thanks a lot
Patrice
Fri Jan 23, 2015 7:47 am
haavarda offline
Hi Patrice,
I am not Matt, but I can try to give an answer anyway. I am not 100% sure what you are asking, but I think you will find what you are looking for I you select trigger on Z-Wave event and Z-Wave command received.
If you do this, you can select type of event to trigger on. Button 1 on/off etc. You can then select the appropriate action.
Håvard
Håvard
Fri Jan 23, 2015 7:54 am
PME999 offline
Thanks Havard
Sorry if it was not clear.
The problem is that I don't have in the pull down menu other choice than battery level update and any command. The problem is the same explained by David just before.
I think the device is not recognized in indigo to be able to trigger a scene. I did the inclusion several times after resetting the key fob with same result.
When I push the key fob buttons, I can see in the log the scene and number received, but no possibility to trigger the event.
Thanks again for your help
Patrice
Sat Jan 24, 2015 11:57 am
You probably have newer versions of the module, which have a different model ID then what is in Indigo. Perform the Define/Sync again, then copy/paste the Event Log results into a reply post and we'll get the model IDs added. We've already added David's model ID but without your Event Log snippet I don't know if that is the same model ID you have.
Sun Jan 25, 2015 11:23 am
PME999 offline
Hello
Thanks for the answer.
Here below the result of the new sync with the new key fob I have :
Z-Wave Syncing - started for device "ZWAVE Telecommande Patrice"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Portable Remote Controller - 00010058
Z-Wave Syncing - retrieved protocol version 3.83, app version 1.02
Z-Wave Syncing - retrieved class hierarchy: Controller : Portable Controller : Portable Remote Controller (01 : 01 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 70v1 72v1 73v1 59v1 5Av1 5Ev1
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "099 - ZWAVE Telecommande Patrice" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved battery level of 26%
Z-Wave Syncing - complete
Z-Wave received "099 - ZWAVE Telecommande Patrice" status update battery level 26%
I tried to change the parameter 250 but impossible
Thanks again for help
Sun Jan 25, 2015 1:10 pm
PME999 offline
Just add that previous key fob is working perfect and recognized like "key fob DSA22" (I have one I have purchased 1 year ago) but the new ones I've bought 1 week ago are recognized like "portable remote controller"
Patrice
Mon Jan 26, 2015 7:20 pm
Hi Patrice,
We've added the model ID for your key fob to Indigo, so hopefully it will work in the next build. If you would like to try it before we release it then contact us (contact form on our home page) and we'll provide you with a pre-release version of it.
Mon Jan 26, 2015 11:41 pm
PME999 offline
Thanks Matt
I will fill the form to test it
Patrice
Sat Feb 28, 2015 2:55 pm
shapa offline
It works fine for me (gen5), the distance is MUCH better (it is using z-wave plus to talk with UZB1 stick?).
Going to sell all my previous version keyfobs now :)
Could you please add parameter 250 settings (scene mode) to the device configuration? Manual adding works, not very convenient
The manual is available here:
http://www.swiss-domotique.ch/index.php ... Guide.html
Sun Mar 01, 2015 11:44 am
Indigo does have parameter 250 UI ("Enable scene mode for all buttons"). If you aren't seeing it, then Re-Define/Sync it then copy/paste the Event Log results into a reply for me.
Mon Mar 16, 2015 8:23 am
Andy_Wismer offline
Hi
I'm having the same probs with the new FOB:
Indigo Device "Key FOB Remote 1" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.301
Node ID: 27
Model: Portable Remote Controller
Model ID: 00010058
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 3.83
Application Version: 1.03
Model Definition Version: 0
Library Type: 2
Class Name: Portable Remote Controller
Class Hierarchy: 01 : 01 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 70v1 72v1 73v1 59v1 5Av1 5Ev1
Features: battery, beaming, waking
Neighbors: - none -
Associations: 1:[1]
Config Values: - none -
Applied for an updated version to "test" (& use... ;-)
Andy
Wed Mar 18, 2015 7:11 am
Andy_Wismer offline
Hi Matt
Just to confirm that, after finding out how to change the FOBs mode from lern to use, both new ZW088s are working great.
Good Job!
Best Regards
Andy
Sat Mar 21, 2015 4:39 am
shapa offline
Matt,
Nope, it's not fully supported :) Probably ID should be added.
Z-Wave Syncing - started for device "161 - Portable Remote Controller"
Z-Wave Syncing - retrieved wake interval of 0 minutes
Z-Wave Syncing - device "161 - Portable Remote Controller" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - changed device "Ela KeyFob" address from undefined to 161
Screenshot 2015-03-21 10.40.31.jpg (183.7 KiB) Viewed 8779 times
Sat Mar 21, 2015 9:55 am
We have that model ID already added to an internal build of the Z-Wave library. If you'd like to try it out now then email us.
Sat Mar 21, 2015 1:31 pm
shapa offline
Matt, 4-1 works with a new lib, but Gen5 KeyFob still don't have parameter 250 available in the menu. Not a big deal, changing manually and it works.
BTW new keyfob has different wakeup procedure (need to push "learn" hole for a 3 seconds)
