unowen wrote:I think it might be line noise, but if it is, I'm not sure what to do about it. Any suggestions so I can finally get a good nights sleep?
support wrote:It could be a few things. Do you have any other X10 transmitters (or 2 way devices) that might be sending out X10 signals?
support wrote:From another post, it sounds like you are using the CM11. I suspect the CM11's internal scheduling is firing off events. If nothing is showing up in the Indigo event log, then Indigo is not the initiator of the X10 signal and for some reason cannot see the signal (possibly because the CM11 itself is sending it).
unowen wrote:I have a wireless transceiver, however, if that was getting signals, wouldn't it show up in the Indigo log? In fact, if there was a valid "signal" being sent, wouldn't it show up in the Indigo log?
unowen wrote:The odd thing is that I was using Thinking Home and have never had this problem in the past, only this last week and a half or so.
unowen wrote:Hopefully it won't happen again, but I still think it might be a problem with line noise.
unowen wrote:On a side, anyone know of any place to get decent dimmer switches for less than $20? Home automation costs an arm and a leg if you want anything better than generic X-10 brand stuff.
unowen wrote:...here's the situation now:
No lights are randomly turning on (I don't think).
A couple of the lights seem to be randomly turning off (without a mention in the logs).
support wrote:What type of switches are you using?
unowen (laptop) wrote:Could this be a bug in Indigo? All these problems didn't start until around the time I switched to Indigo 1.2 (although I don't remember if it coincided exactly.)
unowen (laptop) wrote:I've found that turning on and off the lights in the room have an effect on the amount of static on the phone. Could this be related? Any ideas on a fix?
unowen (laptop) wrote:On a side note, when I called X10 about this, they mentioned that I should never put anything on house code M because there is a lot of noise.
unowen (laptop) wrote:Plus, having lights turn on at 4AM tend to make you a little cranky!
support wrote:To be 100% sure, you could disconnect your CM11 from the outlet and see if you still have the random off problem.
support wrote:What type of light is it?
support wrote:It has been my experience that once you get your system signal stable, you'll have very few problems.
jrickmd wrote:What about someone else in your apartment complex that shares wiring who also uses X10? Do you share wiring with other apartment units? Theoretically, that should show up in your Indigo log... but may be worth a shot asking around.
support wrote:It could be noise generated by some appliance, power strip/surge protector, electronic power supply, loose wire, etc. You haven't mentioned using any X10 plug-in filters on any equipment -- are you?
Do the modules ever randomly turn on during the day or is it only when you are in stage 4 sleep?
