Newbie - I've checked these forums back through Nov 04 and was unable to find an answer. I hope someone here can answer a couple of questions.
I bought Indigo 1.5.5 to run on my iMac (10.3.7). Originally ran Smarthome software on a PC. I have all X10 devices.
So first question is, on the new device window, how do I match up my devices to what is on that window? I've checked X10, Smarthomes and several other sites and can't seem to find the answer. Is there somewhere that cross-references similar devices from different manufacturers/distributors?
I think I've found a signal problem (old home). Is there a way to send signals across different wiring circuits via transceivers? I have several TM751's. Is there a device that can sit on the same circuit the PowerLinc 1132CU is on and transmit to these 751's on another circuit within the same house? e.g. The PC was plugged into the outlet on an adjacent wall in the same room I have the iMac and PowerLinc. The PowerLinc can turn on lamps on it's wall but not the adjacent wall or the living room at the oposite end of the house.
Finally, can my camera's work on Indigo? If so where do I find the info to do so?
TIA.
Mike
