BruceP wrote:Is there a way to turn off motion sensors?
I have one in the garage that rings a chime so I know someone is in the garage. When I go out to do some work it , obviously, continues to chime.
Anyway around this other than placing the chime on a lamp module? (and that is really ugly)
Are you using a Trigger Action to sound the chime? If not, then put the chime on a different X10 address and use an Indigo Trigger Action to sound the chime when the motion detector goes off.
Once you have done this, you can disable the Trigger Action. You can either do this manually via the "enable" checkbox in the main window, or you can create another Trigger or Time/Date Action that executes the action type "Disable Trigger Action."
Regards,
Matt
