pyatv: a python client library for the AppleTV
Wed Mar 24, 2021 3:14 am
Stoutjesdijk offline
Hi all,
I came across pyatv (https://pyatv.dev), a python client library to read and control an Apple TV.
It is very simple to install with
pip install pyatv
Second step is pairing, which is quite easy, too. After that you are in business, and you can start bossing your AppleTV around.
To play around with it, I currently have a very simple (very dirty!) python script combined with an Indigo variable and trigger. I put a new command into the variable, and it is sent to the appleTV. I need to figure out how to do this in a better way, and more importantly: how to receive events from the AppleTV. A simple plugin is probably enough but I have never written one.
import subprocess
var = indigo.variables[352797377] # AppleTVCommand
command = "/Library/Frameworks/Python.framework/Versions/3.9/bin/atvremote --id C8:69:CD:4D:75:49 --mrp-credentials `cat /Users/media/.appleTVcredentials` " + var.value
proc = subprocess.Popen(command, stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True)
out, err = proc.communicate()
indigo.server.log(u"command error: %s" % err)
indigo.server.log("Sent AppleTV command %s" % var.value)
Anyhow, thought I would share the find!
EDIT: corrected typo in title
Best regards,
Mark
Trying to tie it all together...
| Indigo | Plex | NAD M33 | Unifi | LG WebOS | Tado | Sonos | SolarEdge | HUE |
Wed Mar 24, 2021 5:03 am
Re: pyatv: a python client library for the AppleTV
While working out a way to integrate pyatv better with indigo, I noticed that pyatv uses python3. Looks like a slight wrinkle.
Best regards,
Mark
Wed Mar 24, 2021 8:49 am
Yep - but we will someday move to Python 3. In the meantime, you can continue to run it like you show above and at least have control. If anyone else is looking at this and doesn't have Python 3 preinstalled (macOS Mojave and earlier), you can run the Python 3 installer from python.org somewhat safely (it doesn't appear to interfere with your Indigo install - YMMV).
Wed Mar 24, 2021 10:26 pm
That looks like a nice candidate for a new plugin.
I might have a look at it.
Karl.
Thu Mar 25, 2021 6:55 am
That would be great . Let me know if I can help, although my Python knowledge is at this time very limited.
I am currently discussing with the author a way to get around the python version issue.
Best regards,
Mark
Thu Mar 25, 2021 7:00 am
Calling another python from an indigo plugin and sending commands and receiving output is not the issue.
The challenge is to make sure that all the python 3 modules are installed.
The plugin should also work with older Mac OS that do not come with py3. And also the open ssl libs have to be there.
Karo.
Thu Mar 25, 2021 8:14 am
mundmc offline
Great find!
Karl if you pluginize this you will continue to be my indigo hero.
Thu Mar 25, 2021 9:34 am
That’s my weekend challenge.
Thu Mar 25, 2021 10:15 am
good news: got the command line version to work on my MAC pro 2012 w mac os 10.14.6
1. install x-code
xcode-select —install
2. install python3 (do not use home-brew)
go to https://www.python.org/downloads/release/python-392/
and download the 64 bit installer and install (all point and click)
3.and download /install pyatv
pip3 install pyatv
all together took 5 minutes
Rest will be plugin design : device.xml, actions, menus, reading and writing commands
 python3 atvremote.py scan
Scan Results
   Model/SW: 4K tvOS 14.5
    Address: 192.168.1.xx
        MAC: 40:CB:C0:D0:xx:xx
 Deep Sleep: False
Identifiers:
 - 01F74624-B8BB-4EF9-9E9E-xx
 - 40:CB:C0:D0:xx:xx
Services:
 - Protocol: MRP, Port: 49153, Credentials: None
 - Protocol: AirPlay, Port: 7000, Credentials: None
   Model/SW: 4K tvOS 14.3
        MAC: D0:D2:B0:88:xx:xx
 Deep Sleep: False
Identifiers:
 - 0721B1F4-4CE5-4EA7-86B7-xx
 - D0:D2:B0:88:7B:77
Services:
 - Protocol: MRP, Port: 49152, Credentials: None
the files are in
/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/pyatv for MAC OS 10.14
and
/System/Volumes/Data/Volumes/XXXX/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/pyatv for MAC OS 11.2
XXXX is your disk volume name
Thu Mar 25, 2021 10:25 am
Korey offline
Yes!!
This will be a fantastic addition!!!
Go Karl GO!! :D :D
Korey
Thu Mar 25, 2021 11:26 am
Different Computers offline
This is pretty exciting!
Thu Mar 25, 2021 11:34 am
pressure is on
Thu Mar 25, 2021 10:53 pm
here the first green shot:
Screen Shot 2021-03-25 at 23.50.48.png (66.37 KiB) Viewed 3305 times
can only read the apple TVs
and very simple read out properties, but it seems to work
Sat Mar 27, 2021 12:25 pm
Amazing speed Karl. I'm trying to figure out how to do it all with Node-Red but you're beating me to it. I think I'll wait :-)
Best regards,
Mark
Sat Mar 27, 2021 12:29 pm
Some competition is always good.
