Ubiquiti USG3 died
Thu May 27, 2021 7:46 am
IndigoSam offline
Re: Ubiquiti USG3 died
durosity wrote:
Yes they can connect to SecuritySpy.. in unifi protect on the UDMP you can see a RTSP stream URL that you can then add to SS.. so rather than SS getting the stream directly from the UDMP rather than the cameras
RogueProeliator wrote:
I switched over to using the Unifi device for output of the cameras to HDMI, but before that was using a Raspberry Pi 4 to combine the streams from the cameras (directly from the camera, not going through the Protect software). The same type of thing could be done to other systems. Keep in mind, though, you won't have central control of the camera I don't believe (or more limited at least) as compared to it on the Protect system. That is, you may have to go straight to the camera's web interface to change settings.
Thanks both!
Sam
Thu May 27, 2021 8:49 am
I have a spare usg3, kept it after I upgraded to usg4pro
If you like I can send it to you for postage +
Fri Jun 04, 2021 5:25 am
MarcoGT offline
I step into just to ask how you set up homebridge+unifi video.
Are you using the homebridge/homekit plugin?
Users browsing this forum: No registered users and 20 guests
