Homekit, Thread and Indigo
Fri Nov 13, 2020 11:22 am
Welshdog offline
So the relationship between Homekit and Indigo has always been a little strained. Apple didn't offer anything that would help integrate the two so someone had to make HomekitBridge. That's fine, but it didn't seem ideal to me and added more complication and instability to any Indigo setup.
So Apple has announced Thread compatibility in Homekit. Thread seems to be a unifying network tech that could help bring things together. I noticed that Insteon was a member of the Thread group as well as many of the other home automation tech companies.
So is Thread going to be something that will work with or extend Indigo? Will it offer a way to get Homekit integrated into an Indigo home?
Fri Nov 13, 2020 12:36 pm
Re: Homekit, Thread and Indigo
There is a consortium of vendors that have agreed to some degree to try to create a unified standard. This goes far beyond Google Thread - it's the entire stack from the physical layer (802.15.4 which thread and ZigBee are built on, ethernet, bluetooth, wifi) all the way up to the application layer (HomeKit, Alexa, Indigo, etc).
We LOVE standards. We are, unfortunately, in a business where there is very little in the way of standards.
If such a standard appears, we will definitely want to support it. I have no idea how that will effect Apple's HomeKit walled garden since they haven't said anything more about it (AFAIK).
It is still very early so there isn't much information beyond the original statement (I don't believe they've released the draft spec yet), so we clearly can't comment on something that has no real substance. We are very interested however, and we really do hope that something comes of it. We were super hopeful about ZigBee, but that really didn't pan out too well in the end. Hopefully, this new group will get things moving in the right direction.
Fri Nov 13, 2020 1:16 pm
Welshdog offline
Ah I see. So Thread is part of CHIP and we haven't heard anything worthwhile about CHIP since the initial announcement. Time will tell I suppose.
Fri Nov 13, 2020 1:47 pm
Just chipping in my two cents here but I’d argue that HomeKit bridge is more stable than native HomeKit devices, and it’s certainly not complicated to setup. I’d also say it’s a better and more efficient interface to Indigo than indigo touch is (sorry Matt and Jay!) I currently push 120 devices from indigo to HomeKit using it and it’s as stable as a rock.. I had a bit of an issue with it with iOS 14.0 but .1 fixed that.
Fri Nov 13, 2020 2:29 pm
RAID5 offline
If you are looking for an easy way to connect HomeKit and Indigo, have a look at Hoobs.
Also there are things on the way with Apple and Chip. The new HomePod mini has a thread antenna integrated.
RAID5 "A happy Swede addicted to automation"
Sun Nov 22, 2020 11:11 am
Oh I didn't know they'd added Indigo support to Hoobs! How does it differ from C4Ws Indigo plugin?
Sun Nov 22, 2020 11:13 am
RAID5 offline
I just hade a quick look and it look a lot similar.
Sun Nov 22, 2020 11:17 am
I'll have to have a poke at it! Thanks for the heads up!
Mon Nov 23, 2020 12:32 am
mundmc offline
https://homekitnews.com/2020/04/17/hoob ... ox-review/
This is intriguing. It reminds of the Revolv (i think that was it’s name), only via the software layer.
Mon Jan 04, 2021 4:11 pm
Espressomatic offline
This? https://github.com/webdeck/homebridge-indigo2
From github page: "This plugin is designed to be run in an embedded homebridge instance that is installed as part of the HomeKit Bridge Indigo plugin."
Tue Jan 05, 2021 4:39 am
mclass offline
Rumour has it that the draft spec has been issued to participating companies: https://staceyoniot.com/project-chip-releases-draft-specification-just-in-time-for-2021/
Tue Jan 05, 2021 5:12 pm
siclark offline
I’m looking to upgrade my zigbeeUSB stick and was looking at this stick
https://electrolama.com/projects/zig-a-zig-ah/
That interestingly for this discussion also supports thread as is 802.15.4g.
I’ve also seen that Google has released openthread.io
Not that I know what any of this means, and certainly no use to end users before there are devices available but interesting that it’s there to play with now.
Users browsing this forum: No registered users and 19 guests
