Monoprice Z-Wave Plus PIR Multi Sensor, Temp, Humid, light
Thu Feb 20, 2020 3:59 pm
Different Computers offline
https://www.monoprice.com/product?p_id=15902
Quite a deal, and I can confirm they're very reliable with Indigo.
Thu Feb 20, 2020 6:16 pm
mundmc offline
Re: Monoprice Z-Wave Plus PIR Multi Sensor, Temp, Humid, lig
They are fair. They DO work with Indigo, but my failure rate with them was a problem. The Zooz versions were more reliable, and they lasted longer (unless the battery has been upgraded on the monoprice from aaa to the 3V variety).
I encountered both PIR failure and temp reading failure. That said, when they worked, they worked well.
Fri Feb 21, 2020 11:35 am
jltnol offline
My issue was the brightness indicator... very little leeway between 0% and 100%. Almost like its On or Off, without much in the middle. But past that, mine has worked just fine.
