30% off on Dome Z-wave
Thu Jul 06, 2017 7:17 am
Different Computers offline
https://domeha.com/shop?promo=take30offbyjuly30
Free shipping too.
Makes their prices a bit cheaper than Amazon's for the same type of device from a cheaper manufacturer. Reports here say the water shutoff (for $66) works out of the box with Indigo.
Thu Jul 06, 2017 10:02 am
rapamatic offline
Re: 30% off on Dome Z-wave
Price looks good and I like the look of their leak sensor and sirens too - do you know if those devices also all work with Indigo?
Thu Jul 06, 2017 10:34 am
Nope, I only searched here for the valve control. Others might. Search!
From the text on the web site, Dome seems to emphasize their stuff is all standards compliant, so there's a good chance it works fine.
Thu Jul 06, 2017 10:37 am
rapamatic offline
A search in the forums and in the supported device documentation turned up nothing, that’s why I asked here.... I may order some to try anyway and will update. It looks like their little power outlet switches work out of the box... so it’s likely the leak sensors would. Unclear the siren will (since a lot of different options for that - different chirps and beeps)....
Thu Jul 06, 2017 1:47 pm
akimball offline
I have two water valve units. They work great. I have one mouse trap unit....that doesn't integrate yet.
I modified an Indigo Sprinkler Icon to look like a water valve... this is my control on iOS:
-Al
Fri Jul 07, 2017 5:12 am
norcoscia offline
Good info - I took a look and noticed their Door/Window Sensor Pro - 29 dollars (before the 30% off) and it say the battery will last 10 years - I like the sound of that - has anyone tested one of these with Indigo?
I did a quick search here but no luck finding any posts other than the valve....
_______
Norm
Fri Jul 07, 2017 3:04 pm
akimball offline
I can vouch that the domo mouse trap has extremely limited compatibility currently....only reports battery level and not zap triggers. Domo water valve is 100% compatible out of the box. I know nothing of the other domo products.
-Al
Tue Jul 11, 2017 4:33 pm
Hey, I just got mine paired up and thought I'd let others know: for pairing, where the direction says "press the 'open/close" button quickly 3 times in a row" what they seem to actually mean is "turn it on and off quickly 3 times in a row". In other words, SIX button presses, not three.
Wed Jul 12, 2017 9:25 am
akimball offline
Now about that mouse trap...if Indigo could give me a real-time notification when the domo mousetrap zaps the mouse, I could get the little guy medical help before it's too late.
-Al
Wed Jul 12, 2017 10:01 am
norcoscia offline
I wish the trap did work - it is perfect for my crawl space - I have pex pipes down there and if a mouse got in somehow and decided to chew on one it would be a bad day. I don't really want to go down there to bait and check traps - notification would be great.''
Wonder if Domo products are on the upgrade list?
_______
Norm
Wed Jul 12, 2017 10:06 am
norcoscia offline
AI - I just thought of something - when the trap zaps it should send a z-wave command - bet you could listen for it an set a trigger - wouldn't that make it 100% or do you have other problems with it.
_______
Norm
Wed Jul 12, 2017 10:30 am
akimball offline
Norcosica, Perhaps I could find some way to get it to work with much reseach but I've kinda been hoping support would be added in a future upgrade. To avoid torturing a small animal, perhaps they could electrocute a hot-dog as they add this functionality to Indigo.
-Al
Wed Jul 12, 2017 10:35 am
norcoscia offline
Should be easy (I think) - just trigger it - and capture the message - then put it in the dialog.
Should be easy - famous last words :-)
_______
Norm
Wed Jul 12, 2017 10:37 am
akimball offline
Hmm, okay now I see what you mean. Will give it a shot.
-Al
Fri Sep 15, 2017 3:20 pm
norcoscia offline
Hi, Al, wondering if you got this working - I was just down in my crawlspace and I noticed I was not alone :shock:
Matt did help me with an unsupported Dome open/close sensor - with his help, I'm able to set a variable from an action that is linked to a message the unsupported sensor sends for open or closed.
I guess I could try the same thing with the mouse electric chair but would like to know if you had any luck before I drop the cash..
If you get a second and don't mind, pls let me know....
_______
Norm
