Netatmo Welcome
Sun Jan 01, 2017 8:30 am
MarcoGT offline
Netatmo Welcome
As Christmas gift from my wife I got the Netatmo Welcome.
I had a quick look in the forum and it seems that no plugin exists, but there are API available.
What I am interested in is the home/away trigger in order to use it in Indigo.
Did anyone already try to integrate into Indigo?
Marco
Sun Jan 01, 2017 5:43 pm
peteinau offline
Re: Netatmo Welcome
I have one, I'm currently using IFTTT and the BetterEmail plugin to get the home/away status of people that I've been using for a while now. I'd love a plugin if someone wants to make one!
Pete
Mon Jan 09, 2017 5:58 am
MarcoGT offline
Re: Netatmo Welcome
At the moment I am not interested in home/away status of people (we are two+baby :mrgreen: ) but I would like to set home/away status of the house
But thanks for the hint, I will have a look at it
Tue Jan 17, 2017 11:53 pm
MarcoGT offline
Re: Netatmo Welcome
I played a little bit with Welcome+IFTTT and it works, but it seems somehow slow.
Face detection is, as expected, very fast, but the chain IFTTT+eMail trigger in Indigo slows everything.
Need to play a little bit with the API...
Wed Jan 18, 2017 8:18 am
FlyingDiver online
Re: Netatmo Welcome
Is there an IFTTT channel for the Welcome? If you want to trigger an action in Indigo directly from IFTTT, without using email, check out viewtopic.php?f=216&t=17281
Thu Apr 27, 2017 1:21 am
racarter offline
Re: Netatmo Welcome
I've written a plugin for the Netatmo Welcome camera.
Before installing the plug-in you must obtain Netatmo ‘Client ID’ and ‘Client Secret’ keys by registering at dev.netatmo.com. Accept the Terms and Conditions but don’t tick the ‘Netatmo Enterprise’ box. You will also need the email address and password which you used when setting up your Welcome camera.
Once you've entered these details into the plugin config page the plugin will obtain authorisation from Netatmo and fetch presence data. For each face in your Netatmo database an Indigo variable will be created in a folder called Netatmo and set to 'Home" or 'Away'. These variables can then be used to trigger actions in the usual way. The plugin polls Netatmo every 30 seconds, or less frequently if you prefer; this is configurable. Netatmo API has a web hook facility which would seem to obviate the need for polling, but I have no idea yet how (or if) this would work with Indigo.
Please note that the plugin does not currently fetch video or snapshots and is unlikely do so in the future. The Netatmo registration and authorisation requirements for live video are much more onerous (for privacy reasons I assume).
Here's the download page:
https://www.indigodomo.com/library/400/
Alan
Thu Apr 27, 2017 5:29 am
MarcoGT offline
Re: Netatmo Welcome
I would be interested to do it.
What does the plugin currently make?
Thu Apr 27, 2017 5:49 am
racarter offline
Re: Netatmo Welcome
@MarcoGT -What does it make? Sorry, I don't understand what you mean.
Thu Apr 27, 2017 10:30 pm
MarcoGT offline
Re: Netatmo Welcome
I mean, you said it does not take snapshot or video, what is the plugin intended to do?
Fri Apr 28, 2017 1:13 am
racarter offline
Re: Netatmo Welcome
See above:
"For each face in your Netatmo database an Indigo variable will be created in a folder called Netatmo and set to 'Home" or 'Away'. These variables can then be used to trigger actions in the usual way."
Sun Apr 30, 2017 8:59 pm
peteinau offline
Re: Netatmo Welcome
Sent you a message, I'd be happy to teat it out!
Pete
Sat Jan 13, 2018 3:13 am
racarter offline
Re: Netatmo Welcome
I've extended this plugin to support the Netatmo Healthy Home Coach internal air quality monitor.
Thu Dec 05, 2019 12:37 pm
boekweg offline
Re: Netatmo Welcome
Hi there, I'm trying to get the Netatmo healthy home working. I have the plugin and ticked the box for this device. It does show up in the devices list but shows an error state. I have the id and security in place, my Netatmo welcome does work but nit the healthy home. Any ideas?
Thu Dec 05, 2019 12:57 pm
racarter offline
Re: Netatmo Welcome
Any clues in the log?
If you tick the config box to write Netatmo Healthy Home messages to the log and send me the result I'll have a look.
Thu Dec 05, 2019 1:04 pm
boekweg offline
Re: Netatmo Welcome
This is what I get after reloading the plugin:
It shows a device creation error
Reloading plugin "NetatmoWelcome 1.3.1"
Stopping plugin "NetatmoWelcome 1.3.1" (pid 98540)
NetatmoWelcome Stopping Netatmo Multi plugin
Stopped plugin "NetatmoWelcome 1.3.1"
Starting plugin "NetatmoWelcome 1.3.1" (pid 3791)
Started plugin "NetatmoWelcome 1.3.1"
NetatmoWelcome Starting Netatmo Multi plugin
NetatmoWelcome Current tokens are valid; authentication not required
NetatmoWelcome Error Healthy Home device creation error: Unknown error
NetatmoWelcome ********************************************************************
NetatmoWelcome Starting Netatmo Multi monitoring thread
NetatmoWelcome Access and Refresh Tokens will be saved on shutdown
NetatmoWelcome Welcome camera(s) will be polled
NetatmoWelcome - Camera polling set to 30 seconds
NetatmoWelcome - Last Seen variables will be created/updated
NetatmoWelcome - Persons forgotten in Netatmo app will not be deleted
NetatmoWelcome Healthy Home air quality monitor(s) will be polled
NetatmoWelcome - Monitor message logging is on
NetatmoWelcome Weather station(s) will be polled
