kidney wrote:...Also do you need a cloud sub for this to work?
No.
HTTPd Debug AuthHandler: GET from 10.0.1.6:56758 for /setvar?doorbird=pressed
HTTPd Debug AuthHandler: Request has no Authorization header
kidney wrote:ok because, I'm always getting this error message "Basic Authentication Required" when I try the first instruction and the log show this also
- Code: Select all
http://192.168.1.2:18009/motionsensor
# by Karl Wachs
# July 16
# modified for DoorBird by NeilK
# Minor changes and edits by Berkinet
import os
import indigo # just to supress lint errors
from BaseHTTPServer import BaseHTTPRequestHandler, HTTPServer
PORT = 18009 # port number to be used by DoorBird on IndigoServer to GET url's defined in the API
actionMotion = xxxxx # ID of Action Group to run when DoorBird motion sensor is triggered
actionOpen = xxxxx # ID of Action Group to run when the open button in the app is pressed
actionBell = xxxxx # ID of Action Group to run on the Doorbell rings.
# See DoorBird API at www.doorbird.com/api to set the URL to get based on the action for /motion.html , /doorbell.html , /button.html
# For example: http://192.168.1.10/bha-api/notification.cgi?url=http://192.168.1.2:18009/motionsensor&user=&password=&event=motionsensor&subscribe=1
class S(BaseHTTPRequestHandler):
def _set_headers(self):
self.send_response(200)
self.send_header('Content-type', 'text/html')
self.end_headers()
def do_GET(self):
self._set_headers()
self.wfile.write("<html><body><h1>Indigo DoorBird Forwarding</h1>"+str(self.path)+"</body>")
if self.path == "/motionsensor":
indigo.server.log("DoorBird sent motion command", type="DoorBird")
indigo.actionGroup.execute(actionMotion)
if self.path == "/dooropen":
indigo.server.log("DoorBird sent Button command", type="DoorBird")
indigo.actionGroup.execute(actionOpen)
if self.path == "/doorbell":
indigo.server.log("DoorBird sent doorbell command", type="DoorBird")
indigo.actionGroup.execute(actionBell)
def do_HEAD(self):
self._set_headers()
def do_POST(self):
# Doesn't do anything with posted data
self._set_headers()
self.wfile.write("<html><body><h1>POST!</h1></body></html>")
def run(server_class=HTTPServer, handler_class=S, port=PORT):
server_address = ('', port)
httpd = server_class(server_address, handler_class)
indigo.server.log("Starting DoorBird httpd..."+"Port...."+str(PORT), type="DoorBird")
httpd.serve_forever()
if __name__ == "__main__":
myPID = str(os.getpid())
indigo.server.log("PID of DoorBird server is:" + myPID, type="DoorBird")
run()
tazswe wrote:A nice feature would be that a webpage with livestream would open up on my TV when somebody pressed the button and closed again after a minute or when I opened the door.
To do this I’m in need of a small python script that opened up a webpage with a long livestream. Anybody that can help me with that....
Different Computers wrote:**IF** you've...
http://192.168.1.100:8000/live?cameraNum=1&viewMethod=0&imageSize=0&windowWidth=1647&windowHeight=1116&42355
mat wrote:OR, you could just answer the door when the bell rings and see who it is
mat wrote:Well, in a single family home, perhaps that might work, and then again maybe not for a number of reasons (ever had an Amazon delivery while you are in the bathroom?). But, in a multi-family dwelling or in case of a remote entry, like a gate, it can be quite useful to have the remote ability even while you are at home.OR, you could just answer the door when the bell rings and see who it is
