New Z-Wave Flood Sensor
Wed Mar 12, 2014 6:04 pm
Re: New Z-Wave Flood Sensor
The model ID for your leak sensor is different (even though it is the same model). I just added your ID so it should work in v6.0.12 once it is available. If you want to try it sooner then email me: indigo-support AT perceptiveautomation.com.
Wed Mar 12, 2014 6:58 pm
mlooss offline
Thanks, I just sent e-mail.
Thu Mar 13, 2014 7:22 pm
mlooss offline
Matt,
is a pre-release available of v6.0.12, I thought it was, I had e-mail support yesterday?
Thu Mar 13, 2014 7:48 pm
Not quite yet. I'll email you more information once it is.
Fri Apr 11, 2014 5:33 pm
wiery offline
Anyone found where to get a wired probe for it ?
Sun Apr 08, 2018 12:57 pm
zini offline
I just got one of these and got it to successfully sync on the first attempt. However, Indigo is saying that there is no device definition (see attached screenshot). I was under the impression that this device was supported by Indigo.
Any thoughts?
Mark
Sun Apr 08, 2018 5:39 pm
Hi Mark,
Re-sync it and copy/paste the Event Log results into a reply for us. And what specific model number is shown on the module?
Sun Apr 08, 2018 5:43 pm
zini offline
Here you go. The box says "Flood Sensor FGFS-101 ZW5 v3.2"
Apr 8, 2018, 7:41:00 PM
   Schedule                        Date & Time Update
   Z-Wave                          Syncing - started for "Kitchen Sink - Fibaro Flood Sensor"
   Z-Wave                          Syncing - retrieved module neighbors list: 2, 3, 4, 5, 6, 7, 8, 15, 19, 20
   Z-Wave                          Syncing - assigning return route to "021 - Kitchen Sink - Fibaro Flood Sensor"
   Z-Wave                          Syncing - retrieved manufacture and model names: Fibaro System - 010F, Notification Sensor - 0B012002
   Z-Wave                          Syncing - retrieved protocol version 4.05, app version 3.02
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
   Z-Wave                          Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 8Ev1 56v1 98v1 59v1 5Av1 9Cv1 5Ev1 20v1 22v1 71v1 70v1 31v5 72v1 73v1 7Av1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, battery, beaming, security, waking
   Z-Wave                          Syncing - retrieved wake interval of 60 minutes
   Z-Wave                          Syncing - device "021 - Kitchen Sink - Fibaro Flood Sensor" wake interval changed to 60 minutes
   Z-Wave                          Syncing - retrieved group 1 associations: [1]
   Z-Wave                          Syncing - retrieved group 2 associations: []
   Z-Wave                          Syncing - retrieved group 3 associations: []
   Z-Wave                          Syncing - retrieved group 4 associations: []
   Z-Wave                          Syncing - group 1 association to interface already exists (skipping)
   Z-Wave                          Syncing - retrieved battery level of 100%
   Z-Wave                          sent "Kitchen Sink - Fibaro Flood Sensor" status request
   Z-Wave                          received "021 - Kitchen Sink - Fibaro Flood Sensor" status update battery level 100%
Apr 8, 2018, 7:41:41 PM
Mark
Sun Apr 08, 2018 6:00 pm
Looks like that one is using a different model ID than the previous ones we've had reported. I've added it to the next bug fix release (7.1.2).
Sun Apr 08, 2018 6:30 pm
zini offline
Matt,
Thank you for your extremely fast support! That sounds great. I am assuming it will work by default then with that release.
Appreciate it, as always.
Mark
Fri Sep 28, 2018 12:57 pm
Indigo 7.2.0 is now available for download and has the new Fibaro Leak Sensor (FGFS101) definition.
Mon Oct 01, 2018 1:15 am
SST offline
Hello!
I still can’t get this to work in Indigo 7.2. Did a new inclusion and a new define and sync but with no luck. Any suggestions?
Fibaro flood sensor -101 v3.3 EU
From the log:
Z-Wave Indigo Device "Fibaro_flood_sensor" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.119
Node ID: 62
Model: Notification Sensor
Model ID: 0B011003
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 4.24
Application Version: 3.03
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 8Ev1 56v1 98v1 59v1 5Av1 9Cv1 5Ev1 20v1 22v1 71v1 70v1 31v5 72v1 73v1 7Av1
Features: routing, battery, beaming, security, waking
Neighbors: 2, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 23, 24, 25, 26, 27, 37, 38, 39, 55, 61
Associations: 1:[1] 2:[] 3:[] 4:[]
Config Values: - none -
Mon Oct 01, 2018 8:28 am
SST wrote:
Model ID: 0B011003
That is a different model ID than the ones previously reported. We'll add that particular one to the next bug fix release (7.2.1).
Sun May 12, 2019 3:51 pm
Indigo 7.3 (and 7.3.1) are now available and have support for the new variant of Fibaro Leak Sensor (FGFS101 and FGFS111).
Mon Feb 03, 2020 1:25 am
Hank.wheeler offline
My Model is also missing: FGFS-101
Indigo Z-Wave Version: 7.4.0
Node ID: 39
Model ID: 0B013002
Protocol Version: 4.05
Application Version: 3.02
Library Type: 3
Command Versions: 20v1 80v1 22v1 84v2 85v1 86v1 71v1 8Ev1 70v1 31v5 72v1 73v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
Neighbors: 3, 9, 11, 12, 13, 18, 21, 22, 23, 38
any chance getting it added soon?
