Thanks for the update wiery, look forward to Indigo supporting the other features.
M.
McJohn wrote:Is it possible to change this in the next update?
McJohn wrote:When the wakeup interval is more then an hour, the settings can't be changed at an earlier moment by the user?
wiery wrote:Matt, i've installed the new Z Wave library and re-sync'd the flood sensor. The additional devices ( temperature and tilt ) showed up. The Temperature sensor doesn't seem to update however, it hasn't updated since just after i re-sync'd about 16 hours ago. The tilt sensor doesn't recognise when you actually tilt the device
Indigo Z-Wave Version: 1.0.143
Node ID: 9
Model: Leak Sensor (FGFS111)
Model ID: 0B001001
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 3.52
Application Version: 23.23
Model Definition Version: 7
Library Type: 3
Class Name: Alarm Sensor (routing)
Class Hierarchy: 04 : A1 : 02
Command Class Base: 71
Command Versions: 80v1 60v2 84v1 85v1 86v1 8Ev1 9Cv1 20v1 70v1 30v1 71v1 72v1 7Av1
Multi-Endpoint Types: 1:(20 : 01), 2:(21 : 01)
Multi-Endpoint Classes: 1:[30], 2:[31]
Features: routing, battery, beaming, waking
Neighbors: - none -
Associations: 1:[1] 2:[1] 3:[1]
Config Values: 2:3 10:300 12:10 5:255
Z-Wave Debug RCVD nodeAwake: 01 08 00 04 00 09 02 84 07 7B
Z-Wave Debug . . nodeAwake: node 009
Z-Wave Debug . . nodeAwake: inhibit count++ to 1
Z-Wave Debug . . nodeAwake: started inhibit sleep timer
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 09 02 80 02 05 3E 57
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 09 03 80 03 64 1F
Z-Wave Debug . . requestBatteryLevel: node 009, level 100
Z-Wave received "009 - Sensor - Bathroom - Flood" status update battery level 100%
Z-Wave Debug . . nodeAwake: inhibit count-- to 0
Z-Wave Debug . . nodeAwake: stopping inhibit sleep timer
Z-Wave Debug SENT goToSleep: 01 09 00 13 09 02 84 08 05 3F 58
Z-Wave Debug . . . . . . . : skipping battery check (next check in 712 mins)
Z-Wave Debug SENT goToSleep: 01 09 00 13 09 02 84 08 05 42 25
Users browsing this forum: No registered users and 24 guests
