How can I control my motorised window shades from Indigo?
Sun Oct 02, 2022 11:41 am
guglez offline
Hi All,
I have several motorised window shades. They are "dumb" and usually they are controlled via a dumb switch. If you press one button - they go up. And with another button, they go down. I have Heltun switches https://www.heltun.com/z-wave-relay-switch-quinto which I use to make them smart. Basically, they act as a z-wave relay which can be controlled by Indigo.
Question - How can I control it from Indigo properly? I would like to be able to know the current state of the shade - is it open or closed or partially opened/closed? I would also like to say something like this to Siri - close window shades in the living room to 60%
Currently, if I want to partially open the shade I have to fully close it and then "press and hold" the relay for several seconds.
How can I achieve this?
Tue Oct 04, 2022 8:27 am
McJohn offline
Re: How can I control my motorised window shades from Indigo
We are using the Fibaro Roller shutters.
https://www.fibaro.com/en/products/smar ... r-shutter/
They are working perfect with dumb motorised window shades.
For the Indigo HomeKit connection we use the famous HomeKitLink Siri plugin.
Hey Siri "Window Shades Kitchen 50%" works very good!
Fri Oct 07, 2022 3:04 pm
guglez offline
In my case I already have relays. I have too many shutters so this fibaro device will cost me too much :(
Wed Oct 12, 2022 10:35 pm
MarcoGT offline
Have a look at Shelly2.5 which can be configured as roller shutter.
I have a mixed setup of Fibaro/Shelly and works fine
Thu Oct 13, 2022 1:00 am
Guglez, I could probably add some functionality to the Zwave Window Controller plugin for this.
You’d have to set some travel times into the plugin by trial and error. ie 10 seconds for full travel therefore 50% open is hold-for-5-seconds.
Peter
Thu Oct 13, 2022 12:12 pm
Londonmark offline
I’d find that useful too!
Mon Oct 24, 2022 2:44 am
guglez offline
Peter,
Can I help you with this somehow?
Tue Oct 25, 2022 10:47 am
It won’t take me long to do, I just need to sit down at it.
I’ll see how I am fixed next week.
Sun Nov 13, 2022 10:22 am
guglez offline
@howartp,
looking forward to this!
Mon Jul 31, 2023 2:44 pm
I'm working on this this week.
Just getting my head back around a) the plugin and b) the request.
Peter
Mon Jul 31, 2023 7:21 pm
ryanbuckner offline
Check out the Bond plugin
Users browsing this forum: No registered users and 22 guests
