Aeon Labs MultiSensor (DSB05)
Thu Apr 13, 2017 4:18 pm
Re: Aeon Labs MultiSensor (DSB05)
Hi Martin,
Try excluding it from the Z-Stick, re-including it, then re-syncing it in Indigo.
Tue May 16, 2017 10:54 pm
anothersphere offline
Weirdly, de-powering one of them, and re powering and synchronising has caused it to decide to do temperature again.
I had also noticed some triggers for it had changed from temperature has any change to z wave command received - is this a case of Indigo not quite understanding what the sensor was saying when I had previously synchronised it?
I have yet to do anything to the other problematic sensor. I will try the same, or possibly I will do so with it plugged in via USB.
Martin Miller
Auckland - New Zealand
Fri Sep 15, 2017 4:48 pm
wjlevin offline
HI - I just updated the firmware in two DSB05 MultiSensors to 1.18 (Aeon told me that the temperature readings would be accurate with the new firmware).
Now I can't get them to sync. I click the button 3 times to have them wake up (I see the LEDs flash) - but to no avail.
Below is the log form a few attempts. Can anyone tell me where I'm going wrong?
Many thanks in advance!
Z-Wave Syncing - started for "Office Sensor"
Z-Wave Syncing - retrieved module neighbors list: 1
Z-Wave Syncing - assigning return route to "003 - Office Sensor"
Z-Wave Error Syncing - failed to assign return route
Z-Wave Error No response from "003 - Office Sensor". Module might be asleep, or is unreachable.
Fri Sep 15, 2017 5:23 pm
The firmware upgrade probably deleted the inclusion with the Z-Stick. So exclude it, re-include it, then try the re-sync.
Fri Sep 15, 2017 11:03 pm
wjlevin offline
Can I get more direction? What do you mean by "exclude it, re-include it"?
Please point me to some documentation.
Many thanks....
Sat Sep 16, 2017 4:36 am
In order for Z-Wave devices to be part of a Z-Wave network, they need to be included in that network (or excluded if they are removed from the network).
There are instructions here :http://wiki.indigodomo.com/doku.php?id=z-wave
Do not delete the Indigo device when you do this. When you're done excluding and re-including, you can point the Indigo device at the new Z-Wave device ID.
Note: I'm crazy swamped IRL and it may be a while before I can respond to messages or bug reports. Thanks for your patience.
