Aeon Labs MultiSensor (DSB05)
Thu Jul 10, 2014 12:35 pm
marceltrapman offline
Re: Aeon Labs MultiSensor (DSB05)
Thank your quick follow up Jay.
Will try this tomorrow and see what happens.
I managed to get the sensors back up so that is good news but re-synchonizing failed again so your suggested solution will, hopefully, bring the network back into shape.
Will keep you up to date :)
Sun Jul 13, 2014 8:06 am
jay (support) wrote:
marceltrapman wrote:
Q1 How can I 'repair' this?
Getting routes right with battery powered devices is a little tricky. Here's what I'd do (in this order):
  1. Bring your motion sensors to your Mac
  2. Resync the motion sensors (wake them up)
  3. Resync the repeaters (keep the motion sensors awake)
This will hopefully make sure that everyone knows about everyone else, and there are no more routes to non existing nodes. Next, repeat these steps for each sensor:
So I tried this but again no joy :(
13 Jul 2014 15:58:06
Z-Wave Error failed to find device parm description for module 5, index 2
13 Jul 2014 15:58:28
Z-Wave Syncing - started for device "Kitchen Motion Sensor"
Z-Wave Syncing - retrieved module neighbors list: 3, 8, 9, 10, 11
Z-Wave Syncing - requesting neighbor list update of "005 - Kitchen Motion Sensor"
Z-Wave Syncing - neighbor list update failed -- will try to update nearby neighbors first
Z-Wave Syncing - requesting neighbor list update of "003 - Engine Room Warm Water Plug"
Z-Wave Syncing - nearby neighbor list update complete (no change)
Z-Wave Syncing - requesting neighbor list update of "008 - Garage Door Switch"
Z-Wave Syncing - nearby neighbor list updated from 4, 5, 6, 9 to 4, 5, 6, 9, 11
Z-Wave Syncing - requesting neighbor list update of "009 - Kitchen Lights"
Z-Wave Syncing - requesting neighbor list update of "010 - Front Door Bell 2"
Z-Wave Syncing - requesting neighbor list update of "011 - Storage Room Repeater"
Z-Wave Error Syncing - neighbor list update failed
Z-Wave Syncing - assigning return route to "005 - Kitchen Motion Sensor"
Z-Wave Error Syncing - failed to assign return route
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Multi Sensor (DSB05) - 00020005
Z-Wave Syncing - retrieved protocol version 3.28, app version 1.18
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Binary Sensor : Binary Sensor (routing) (04 : 20 : 01, base 30)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 70v1 30v1 31v5 72v1
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Error device "Kitchen Motion Sensor" may be asleep. configuration changes will be set during the next wake interval.
Z-Wave Error No response from "005 - Kitchen Motion Sensor". Module might be asleep, or is unreachable.
Sun Jul 13, 2014 5:24 pm
So now the sensors won't even sync when they are withing range (just a few feet) of the Z-Stick?
Mon Jul 14, 2014 4:36 am
Exactly.
The funny thing is that they seem to work but sync and sending a status request fail all the time.
Mon Jul 14, 2014 9:00 am
Are you waking the module?
Status request (and sync) will always fail unless you either have the module powered via the USB mini port or unless you wake the module.
To wake it follow the instructions of removing the battery cover and triple tapping the button. The LED on the front will glow steady if it is in wake mode — if the LED is not glowing steady, then the module is asleep.
Mon Jul 14, 2014 1:04 pm
The LED on the front will glow steady if it is in wake mode. If the LED is glowing steady, then the module is asleep.
I think these contradict each other :?
Anyway, I will try again and make sure I see the LED glow...
Mon Jul 14, 2014 3:19 pm
yep — corrected. :)
Wed Jul 16, 2014 12:27 am
pff, done. Thank you for your support!
Wed Sep 24, 2014 8:47 am
eme jota ce offline
I've replaced an Insteon motion sensor with a Multisensor. It's primary function is to turn on lights, fans, and adjust AC when I walk into the office.
Noticing that the Multisensor is much slower update its motion state in Indigo (and to turn on the lights, etc.) It is running on USB power, not battery. Since there's not a battery drain concern, is there a setting that can be adjusted to make update its state to "On" as fast as the Insteon sensor did?
mjc
Wed Sep 24, 2014 10:03 am
The hardware doesn't delay between the time it senses motion and sends the command. Our experience is that they're super fast, so my guess is that your motion sensor has to route through multiple nodes to get to the Z-Wave interface. Additional "hops" does cause delays in communication. You might try resyncing the devices between the Z-Stick and the motion sensor just to make sure that the best route is getting followed. Start by syncing the closer ones first and work your way towards the motion sensor.
Thu Sep 25, 2014 1:41 am
eme jota ce offline
Thank You Jay,
That was helpful. I'm seeing speed increases after resyncing other Z-Wave devices and the multi sensor, as you described above.
MJC
Fri Nov 07, 2014 5:33 pm
T-Power offline
ftp30 wrote:
Hi There,
is there an easy way to grasp the time at which an update was received from one of the sensors and put it in a control
i.e.
Control Page :
Temperature = 22 C updated 03:55am 25/06/2013
Humidity = 57% updated 03:58am 25/06/2013
Luminance = 255 updated 04:08am 25/06/2013
Motion = ON updated 04:08am 25/06/2013
I am able to do everything but the Time stamp for the update, I know that I sound "lazy" but I am not terribly familiar nor with Applescript and/or with Pyton, if there is an easy "system" way I would love to learn it, if I need to write a script, would any good-will volonteer to give the first indication and than I will implement it from there.
Thanks for your Support
Francesco
Hello,
How did you you get the timestamp to display that format?
T.I.A.
MacMini 2.3 GHz Intel Core i7 16GB DDR3
Indigo Pro 2022.1 macOS Mojave 10.14.6
Fri Dec 12, 2014 9:35 pm
Sully offline
Was wondering the best method to have a Aeon Humidity sensor in a bathroom control a fan based on the other Aeon humidity sensors in the house current value.
IE: run the fan until the bathroom humidity matches the kitchen and bedroom humidity
The fan always comes on when shower scene is loaded from the A button on a keypad link dimmer, so even better would be to have the fan come on as soon as the
bathroom humidity is higher then the other 2 humidity sensors.
Thanks in advance, love this forum and Indigo!!
Sat Dec 13, 2014 5:49 am
I think that I would do this with an embedded script within a trigger.
Trigger settings:
Type: Device State Changed
Device: Bathroom Humidity Sensor - Sensor Value - Has Any Change
Actions:
Server Actions - Script and File Actions - Execute Script
Embedded Python
Untested:
humidityBathroom = indigo.devices[BATHROOM HUMIDITY ID].sensorValue
humidityKitchen = indigo.devices[KITCHEN HUMIDITY ID].sensorValue
humidityBedroom = indigo.devices[BEDROOM HUMIDITY ID].sensorValue
if (humidityBathroom > humidityKitchen) or (humidityBathroom > humidityBedroom):
   indigo.device.turnOn(BATHROOM FAN ID)
elif (humidityBathroom <= humidityKitchen) and (humidityBathroom <= humidityBedroom):
   indigo.device.turnOff(BATHROOM FAN ID)
Certainly not the only way to do it.
Dave
Sat Dec 13, 2014 11:25 am
Sully offline
Thanks Dave, i give this a try!
Trigger settings:
Actions:
Embedded Python
Untested:
Dave
Page 7 of 14 1 ... 4, 5, 6, 7, 8, 9, 10 ... 14
