not only sounds correct,
it also works, funny to notice the routing time delay, z-wave is almost immediate, if it routes it may take few moments..
DU Lou wrote:I have just purchased a few of these to replace some Insteon motion sensors. Has anyone noticed the distance of the motion sensor to be shorter than the Intseon ones? I have the sensitivity turned to max and it seems I have to walk closer to trigger the z-wave modules. Also, since the Insteon modules were boxy I had them just sitting on ledges etc. Since I have to mount the Z-wave ones I was thinking of doing so on the ceiling. Anyone have any thoughts/feedback on this? I have 10 ft ceilings in my home.
~Lou
On the plus side, I noticed the improvement in data/reporting right away compared the Insteon modules. I think I am going to dig my new mixed protocol environment
matt (support) wrote:I have on my ToDo list to add Indigo sensor level temperature adjustments, so that you can have Indigo convert between C & F and also offset the temperature to give it a better baseline. I'm not sure when I'll get to that, but it is on my wish list.
WagnerOne wrote:matt (support) wrote:I have on my ToDo list to add Indigo sensor level temperature adjustments, so that you can have Indigo convert between C & F and also offset the temperature to give it a better baseline. I'm not sure when I'll get to that, but it is on my wish list.
I'm noticing a variance between my DSB05 and other thermometers. I have a DSB05 sitting between 2 free-standing digital thermometers, which are sitting within a few feet of one of my Venstar tstats.
The 2 free-standing and the nearby Venstar all report temps within a degree or so of one another (my 2nd Venstar, while not as nearby, is also in that range). The DSB05, however, is often several degrees off.
70.7 aeotech
73 standalone
73 standalone
74 venstar
Is how it stands currently. The spread might not be as bad as I first thought, but it's too bad for my tastes.
Humidity, as measured by the DSB05 (measured with a group of humidity gauges in a similar setup), is off several points too.
Matt, your idea of allowing for offset calculations for a sensor device in Indigo is a great! Looking forward to that.
In the meantime, is there a recommended way to get more accurate readings from my DSB05? I suppose every time it updates temperature values, I could run triggered script to put the more accurate calculated value into a variable?
# amount to adjust current value
adjustValue = 4
# current value as reported by sensor
currentValue = indigo.devices[543518302].sensorValue
# adjusted value (assumes positive ajustment - change to minus if negative)
adjustedValue = currentValue + adjustValue
# record adjusted value in related indigo variable
indigo.variable.updateValue(414235954, value=str(adjustedValue))
dduff617 wrote:several bathrooms in my house have vent fans which plan an important role in eliminating excess humidity.
right now, i have the fans on switching relays and i use indigo to implement a simple timer. when fans are turned on, they run for a fixed amount of time, then turn off. (i also have Insteon motion sensors deployed for lights)
i've been eyeing the dsb05 multi sensor as a possible way to do something smarter - i.e., to turn the fan on automatically when humidity reaches a certain threshold, and shut off when it reaches some lower threshold. i may have to use some other intelligence to vary these thresholds based on the ambient humidity, etc…
