matt (support) wrote:Motion will be instant, but there is the typical delay between On->Off->On cycles. That is, it reports motion and the state goes to ON and then won't report motion unless enough time passes that Off is sent to indicate no motion.
matt (support) wrote:Also note that MacHomeStore.com has a good price on the MultiSensor right now. Given it is really 4 sensors-in-one, that comes out to just $13.75 per sensor.
matt (support) wrote:Correct, there is a Device Setting UI to change the Off Delay, as well as a setting to change the Reporting Interval for the temperature/humidity/luminosity sensors. It all (hardware and Indigo's interface with it) seems to work very well, IMO.
matt (support) wrote:What did the Event Log show? Note that Indigo cannot change the setting immediately -- it has to wait until the next time the module sends an "I'm Awake" command, then it changes the setting. The Event Log should show the details.
Dewster35 wrote:Ahh... so that setting IS the hardware and indigo setting until an off command is sent??
