- Posted on
Sun May 28, 2017 12:10 am
kelmk
offline
I have had mixed success with the 2413U. Right away it synced with my dimmer switch no problem and that works great. However I haven't been able to add a motion sensor or contact sensor.
When adding a new instead device I press the set button and it's address shows up in the indigo window. I click Start and everything seems to be working until the last stage Adding the Powerlinc's address to the devices internal link database. It tells me the device is asleep and press the set button so I do. Then it pops up a window saying Failed to establish a link with the device.
Here is my log
PowerLinc Linking - entered discovery linking mode (240 seconds)
Received INSTEON 41.68.AE on (button 1)
PowerLinc Linking - received module button pressed from 41.68.AE
PowerLinc Linking - syncing PowerLinc links (address 44.85.65)
PowerLinc Linking - . skipping: INSTEON plc link to controller 00.00.00, flags 03, group 01, data FF 00 FF
PowerLinc Linking - . . adding: INSTEON plc link to controller 41.68.AE, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . adding: (not added -- probably already exists)
PowerLinc Linking - sync complete
PowerLinc Linking - PowerLinc links updated
PowerLinc Linking - sending engine version request to 41.68.AE
PowerLinc Unexpected command 02 41 (flushing)
PowerLinc Linking - received engine version 02 from 41.68.AE
PowerLinc Linking - sending id request for device information to 41.68.AE
PowerLinc Linking - received id request response from 41.68.AE
PowerLinc Linking - initializing remote device "new device" (address 41.68.AE, firmware version 46)
PowerLinc Linking - initialize complete
PowerLinc Linking - syncing remote device "new device" (address 41.68.AE, firmware version 46)
PowerLinc Linking - syncing all links
Error resending previous command (reply mismatch)
PowerLinc Linking - . . . read: INSTEON dev link to responder 45.4D.44, flags E2, group 01, data 03 00 00
Error resending previous command (busy or unexpected command)
PowerLinc Unexpected command 02 62 (flushing)
PowerLinc Linking - . . . read: INSTEON dev link to responder 45.4D.44, flags E2, group FF, data 03 00 00
Error failed to send command to module - checksum invalid
Error Linking - syncing failed; remote device might be asleep
Error linking failed
PowerLinc Linking - exited linking mode
