Page 2 of 3
Re: Smartenit EZIO Series
Posted:
Fri Aug 31, 2018 1:32 pm
by bgw
It looks like I'm having the same problem that akimball was having on 5/7/15, except without the "IT'S A MIRACLE! It worked..." part...
akimball or anyone else, have you found any reproducible behavior for linking to EZIO8SA/2413S?
Also, the cable which came with my 2413S looked like ethernet on one side, with serial (9-pin female) on the other. So, I just tried using a regular ethernet cable (since the provided cable won't connect to the EZIO8SA) . Maybe this could be a problem? Maybe I need some sort of crossover cable? Looks like only 4 wires are used on the cable they provided. I see that wires 1 and 8 are Tx and Rx on both the 2413S and the EZIO8SA... my current best guess is that I need a cable which crosses over these wires, but I'm kind of inexperienced with this stuff and want to avoid frying anything.
akimball, you mention the "reset" button on the 2413S... I see one labeled "set"... I assume this is fine but maybe another problem?
Thanks very much for any help.
Bruce
Posted:
Fri Aug 31, 2018 2:27 pm
by jay (support)
bgw wrote:Also, the cable which came with my 2413S looked like ethernet on one side, with serial (9-pin female) on the other. So, I just tried using a regular ethernet cable (since the provided cable won't connect to the EZIO8SA) . Maybe this could be a problem?
Yes, sounds like they sent you the wrong cable. I'd contact Smartenit for a replacement cable (very unlikely an ethernet cable would work).
Posted:
Fri Aug 31, 2018 2:45 pm
by akimball
Yes, the set button works as reset (hmmmm perhaps the first time you push it, you “set” and if you do it again you “reset”. ...press it again it’s a rereset.).
Most 3 year olds agree....I’m a funny guy.
Posted:
Fri Aug 31, 2018 4:34 pm
by bgw
Great, thanks for all the super-quick feedback... I will try a different cable. I asked smartenit to send me one... but I might just hack something together with wire nuts to test it... I'm guessing that might work OK for serial stuff.
Posted:
Thu Sep 06, 2018 10:30 am
by bgw
It looks like the cable I need came with the ezio8sa, and NOT with the 2413S. Problem is, I must have misplaced the cable...
I got this message from smartenit:
"The EZIO8SA ships with a Cat 5E patch cable (3ft). If your Ethernet cable did not seem to work, then what you may need is a 12V power supply to power up the EZIO8SA. The cable you received with the Serial PLM is the correct serial cable (RJ45 to Serial) for that PLM."
I tried a couple different cat5e cables, and also one where I crossed pins 1 and 8 (tx and rx). None of those worked.
Jay, you wrote " (very unlikely an ethernet cable would work)."... how confident are you about that? Just trying to figure out if I should abandon that route of experimentation.
I have to say, it's pretty annoying that they don't put the insteon address of the ezio8sa somewhere on that thing...
Another piece of info, I have been using a multimeter on the 12V and GND pins of the ezio8sa to see if it's powered on (no power LED...), and it's reading about 11V. I wonder if the unit might be having problems, or if this is insignificant.
I guess I could just get a couple 5010J's or 5010V's but it seems like a waste of the hardware I have on hand. I guess I have to figure out how valuable my time is...
Posted:
Thu Sep 06, 2018 12:19 pm
by jay (support)
bgw wrote:Jay, you wrote " (very unlikely an ethernet cable would work)."... how confident are you about that?
Not super confident. Ethernet cables are usually straight-through, and it sounds like from their reply that should work. It's possible your ethernet cable is a crossover cable (meaning the TX and RX wires are crossed). Most ethernet hubs/switches will detect those kinds of cables and automatically adjust so it may still work fine as an ethernet cable.
Basically, I'm not sure. If they say a normal (straight through) ethernet cable should work, then I'd take them at their word.
IoT8-Z I/O controller
Posted:
Thu Sep 06, 2018 6:26 pm
by MattDinOC
Hi all! I'm reading up a bit on this IoT8-Z device... It seems to be an updated version of the EZIO8SA.
https://smartenit.com/product/iot8-z/Wondering if anyone has any experience with it? It seems to be a native ZigBee device. To add it to an Insteon network, you need to add their ZBPLM device, which among other things, looks like it can serve as a bridge between Insteon and ZigBee. (I'm using words like "seems to be" and "looks like it" because the documentation that I could find is not 100% clear.) When purchasing from smartenit.com, this combo adds up to $190.
The previous solution, the EZIO8SA/PLM Combo, sells for $180 on smartenit.com. And it uses a wired connection between the two devices, which ought to be more reliable.
So I guess this IoT8-Z device is good for a couple different categories of customers:
- people who want to add additional ZigBee devices down the road
- people who already have ZigBee running
In either case, you need to be willing to be a trail blazer, possibly being the first Indigo users of this device
Does that sound like I've got it right?
Matt
Posted:
Fri Sep 07, 2018 8:29 am
by Different Computers
Is the ZBPLM compatible with Indigo???
That would be amazing.
Re: IoT8-Z I/O controller
Posted:
Fri Sep 07, 2018 3:47 pm
by jay (support)
MattDinOC wrote:Hi all! I'm reading up a bit on this IoT8-Z device... It seems to be an updated version of the EZIO8SA.
Matt
I think it's unlikely that it will work. I don't believe the ZBPLM is an actual technology bridge (between Insteon and ZigBee), but rather whatever is talking to it has to know how to speak Insteon and/or ZigBee. Indigo doesn't speak ZigBee natively (though someone could write a plugin as we've stated when discussion the Z-Wave/ZigBee combo interface from GoControl).
Posted:
Fri Sep 07, 2018 3:49 pm
by jay (support)
Different Computers wrote:Is the ZBPLM compatible with Indigo???
Doubtful, but we've never tried it ourselves. In any event, Indigo couldn't use the ZigBee component because we don't speak ZigBee's protocol/API. So, at best, it could function as a an Insteon interface (like a PowerLinc - and, in fact, it's likely a 2413 under the hood with a daughter board to do ZigBee).
Posted:
Fri Sep 07, 2018 5:53 pm
by MattDinOC
jay (support) wrote:I think it's unlikely that it will work. I don't believe the ZBPLM is an actual technology bridge (between Insteon and ZigBee), but rather whatever is talking to it has to know how to speak Insteon and/or ZigBee. Indigo doesn't speak ZigBee natively (though someone could write a plugin as we've stated when discussion the Z-Wave/ZigBee combo interface from GoControl).
Thanks Jay.
It's too bad they don't really explain what's going on here. I'm definitely gonna go with the EZIO8SA/PLM combo. I find it odd that Smarthome doesn't offer any multichannel I/O modules, but glad that Smartenit does!
Posted:
Mon Dec 05, 2022 6:30 pm
by macguyincali
Wasn't sure where to post this. But... Does anyone know if the EZFlora 5010A could be used as an I/O device? I have a few I/OLincs that have died and an EZFlora which I bought long time ago, but never used. I imagine it has some I/O capabilities. Wonder if those could be used to detect a sensor tripping (Dakota Alert). I have 2 additional sensors I need to capture input from but the I/OLincs aren't easy to come by.
Is this worth pursuing or should I look at some sort of Z-Wave I/O option?
Posted:
Fri Dec 09, 2022 2:57 pm
by matt (support)
The EZ-Flora is primarily an output only device for controlling the valve solenoids. It might have a rain sensor input, but I don't believe that is reported to Indigo directly (Indigo doesn't create a sensor device for it). And even when using it for outputs it is pretty specific to irrigation control since only 1 output/valve can be activated at a time.
I'd look at using Z-Wave instead. The FortrezZ MIMO2 supports 2 binary and 2 analog inputs, or the MIMO Lite supports a single binary and analog input.
If you don't mind a battery operated module, then you could use a Z-Wave door/window sensor (some have wire terminals you can patch into).
Posted:
Sat Dec 10, 2022 11:06 am
by bluehouse
I’ve thought about this too as some of my EZIO-6s (with 4 analog I/Os) have died over the years. Last year I bought a Z-wave Zooz Zen17 relay to make a rain inhibitor for my lawn sprinkler. The bonus is that it also has 2 I/O ports.
YRMV but so far I’ve been happy with Zooz products. Plus they have good, prompt support and are relatively inexpensive: the ZEN17 may not have as many I/O ports as the EZIOs do but they’re about 1/4 the price of the old EZIO6s were, as I recall.
Not an endorsement, but I’ve been buying Zooz stuff from the
https://www.thesmartesthouse.com. They have several decent sales/year.
Posted:
Sat Dec 10, 2022 3:48 pm
by akimball
Thanks for the Zooz tips. I was never fond of the insteon IO devices and have wondered about replacements. Any reliability issues with zooz? Latency problems? TIA. -al
