Here:
https://www.indigodomo.com/pluginstore/297/
https://github.com/Ghawken/Holiday/releases
This is a relatively simple plugin (well aren't they all?) which allows you to select country and region, and then will update a variable as to whether today or tomorrow is a Holiday
It basically is a wrapper for the python-holidays library which collates this information for multiple countries/regions.
see here:
https://pypi.org/project/holidays/
Install
Only compatible with Indigo 2023.2 - as it can now download the 2 libraries needed - one of which is obviously the holidays package
Double click plugin Bundle
Plugin Config Settings Only
Select Country and/or Region
Go to Plugin Config
Select Country, Region, language and/or categories of holidays (beware some of these are 'public' holidays which is the default)
Press log Holidays to see what holidays are registered, recorded for checking
To check Holidays that plugin is aware of can, also run Menu item - “Log all Holidays”
Log all Holidays once these details are selected.
eg.
- Code: Select all
Holiday =================== Holidays: Country: New Zealand , Region: None, Lang: Default, Categories: public ===================
Holiday New Year's Day is happening on Mon January 1 2024, which is -26 days away
Holiday Day after New Year's Day is happening on Tue January 2 2024, which is -25 days away
Holiday Waitangi Day is happening on Tue February 6 2024, which is 10 days away
Holiday Anzac Day is happening on Thu April 25 2024, which is 89 days away
Holiday Good Friday is happening on Fri March 29 2024, which is 62 days away
Holiday Easter Monday is happening on Mon April 1 2024, which is 65 days away
Holiday King's Birthday is happening on Mon June 3 2024, which is 128 days away
Holiday Matariki is happening on Fri June 28 2024, which is 153 days away
Holiday Labour Day is happening on Mon October 28 2024, which is 275 days away
Holiday Christmas Day is happening on Wed December 25 2024, which is 333 days away
Holiday Boxing Day is happening on Thu December 26 2024, which is 334 days away
Holiday ==================================================== Check Today / Tomorrow =====================================================
Holiday Is Today a Holiday: False
Holiday Is Tomorrow a Holiday: False
Holiday ================================================================================================================================
- Code: Select all
Holiday ============== Holidays: Country: Netherlands Region: None, Lang: Default, Categories: optional, public ==============
Holiday Goede Vrijdag is happening on Fri March 29 2024, which is 62 days away
Holiday Bevrijdingsdag is happening on Sun May 5 2024, which is 99 days away
Holiday Nieuwjaarsdag is happening on Mon January 1 2024, which is -26 days away
Holiday Eerste paasdag is happening on Sun March 31 2024, which is 64 days away
Holiday Tweede paasdag is happening on Mon April 1 2024, which is 65 days away
Holiday Koningsdag is happening on Sat April 27 2024, which is 91 days away
Holiday Hemelvaartsdag is happening on Thu May 9 2024, which is 103 days away
Holiday Eerste Pinksterdag is happening on Sun May 19 2024, which is 113 days away
Holiday Tweede Pinksterdag is happening on Mon May 20 2024, which is 114 days away
Holiday Eerste Kerstdag is happening on Wed December 25 2024, which is 333 days away
Holiday Tweede Kerstdag is happening on Thu December 26 2024, which is 334 days away
Thats it.
There will be a variable called
Holiday_Today: true or false
Holiday_Tomorrow: true or false
in folder Holidays
This will be updated once a day/and/or on startup or any issues.
Susepcted Usage
As a conditional trigger for schedules etc. to run
e.g.Scheduled Alarm clock:
Within Condition:
If Holiday_Today is false….
Check the holidays listed
I have found that it is very good, but there is one 'Bank Holiday' it lists for me which isn't a 'public holiday'.
Was a bit slow to work that day when alarm didn't go off.... not completely sure anyone understood my excuse!
