Hello all, i have a alarm system from marmitek that works with x10 signals and security camera's that run on the securityspy software, that also supports apple script.
I would like to know if it is possible to make it so that if i switch the alarm on the x10 signal that is given by the alarm can trigger a script that would send a command to security spy to activate the cameraas , and switch them off again if i switch off the alarm.
And secondly if an alarm is triggerd the x10 signal that is send by the alarm to switch a group of lights on at 100%, so that it does not matter if the dim settings that are remeberd don't influence the lights when the alarm is triggerd and always go on at 100%
I have to add that i never have done any scripting, but if this is not possible i dont have a reason at this moment either to go and try to learn it .
Thank you for the help.
Data
