Scripting and Triggers
Fri Dec 07, 2012 8:12 pm
Dewster35 offline
All.. hoping someone could help me out.
I do a lot of trigger firing via variables and now I realize that there is a better way in a lot of instances to handle this. Rather than using a variable to do this, I think enabling/disabling the triggers would work a lot more cleanly.
Now for my problem. I don't know how to call to see if a trigger is enabled or disabled.
Just looking to get some script together that toggles between enabling and disabling a trigger based on that trigger being enabled or disabled.
For example, Trigger A is disabled... I run the script, it sees that trigger A is disabled and then it enables it and vice versa for a toggle. I poked around thinking there would be some sort of action to toggle on/off a trigger as you can do with a device but did not find one.
Help is greatly appreciated!
Sat Dec 08, 2012 10:57 am
Re: Scripting and Triggers
Untested, but I think an embedded python script action like this should get you started:
elem = indigo.triggers[someTriggerIdHere]
indigo.trigger.enable(elem, not elem.enabled)
Sat Dec 08, 2012 2:12 pm
Dewster35 offline
Works great Matt, Thanks!
Really need to learn some basic python some free afternoon.
Users browsing this forum: No registered users and 19 guests
