How do you read temperature via RFXCOM?
Wed Oct 31, 2012 5:44 pm
gmusser offline
Using AppleScript, how do you read the temperature from a sensor via the RFXCOM plugin? The nearest I can find in the Indigo documentation is something like "tell device 'Temperature Porch' / log temperatures as string" but this doesn't work. I presume the plugin devices use different syntax but no one seems to have written any documentation for this.
George
Wed Oct 31, 2012 5:58 pm
Re: How do you read temperature via RFXCOM?
Plugin devices aren't supported in AppleScript. There are 2 options:
  1. Write the script in Python. There's a lot of documentation on how to use Python with Indigo objects in the Technical Documents section of the documentation.
  2. Create a trigger that fires whenever the temp changes on the sensor and use the "Insert Device State into Variable" action in the Action Collection plugin to save the new temp to a variable which you can then use from AppleScript.
Thu Nov 01, 2012 6:28 am
gmusser offline
#2 works nicely. Thanks!
Users browsing this forum: No registered users and 29 guests
